Jon Marshall Tue, 05/04/2010 - 09:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Answered in Lan Routing and Switching.
Jon
George Stefanick Tue, 05/04/2010 - 21:16
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
The switchport nonegotiate command is used to stop the port from sending DTP messages (Dynamic Trunk Port).... if you have an access port that you dont want ti turn into a trunk ....
Alessio Andreoli Thu, 07/19/2012 - 04:56
  • Silver, 250 points or more
Hi there,
static access or the more familiar:
int fa0/1
switchport mode access
switchport access vlan vlan_number
no shut
end
is the last state of the DTP negotiation. When all the DTP negotiations to be a trunk fail, then you fall back in the static access mode where just one vlan can cross the link.  For the use itself of the command read George above
If you are working on HA environments use this command!!!
Alessio
