CUCIMOC Latency
May 4th, 2010
Dear all,
I'm working with cucimoc integration (CCM7, OCSR2). Workstation is XP and 7
Basic features works fine expect very long time (20 second) wich occured to place a call by right clic from MOC Contact (drag an drop is OK).
Same latency appears using cucimoc options tools such as server state, select device, pane info ...
I've just installed last cucimoc realease 7.1.4 but problem occurs again.
An idea ?
Thank for your help.
Gérald
