Device Management CDP Neighbor Update
May 4th, 2010
I have a switch which has had its uplinks moved to peer to a new Switch.
However within Device Managemnet the CDP Neighbor information is not updating, it still has the old information.
I have run Device Discovery and update Inventory with no luck.
Any ideas.
Joe Clarke Tue, 05/04/2010 - 10:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
To what Device Management do you refer?  What version of LMS do you have?
Ian Beck Wed, 05/05/2010 - 04:24
Device Centre and the report on a single host.
I have LMS 3.2.
Joe Clarke Wed, 05/05/2010 - 20:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The neighbor display in Device Center comes from Campus Manager Data Collection, not Device Discovery.  Run a new Campus Data Collection, and when it completes, Device Center should have the proper neighbor details.  If not, you may be seeing a bug in which Data Collection doesn't complete correctly.  If you post the ani.log, it should be easy to determine if that is the case.
Ian Beck Thu, 05/06/2010 - 04:54
I appear to have all the Data Collection jobs defined but nothing is running.
The current ani.log is empty but have the attach backup version.
Joe Clarke Thu, 05/06/2010 - 22:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You are seeing a known bug.  Exactly what version of Campus Manager do you have?
Joe Clarke Fri, 05/07/2010 - 20:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You are seeing CSCtd49439.  If you open a TAC service request, and mention that bug, a patch will be provided to fix this.
