isakmp sa table.
May 4th, 2010
Hi all,
I have one query regarding the L2L Vpn.
I can access the application via tunnel .
But in my show crypto isakmp table. I couldn,t see SA output information in the table..
Kindly advice
Federico Coto F... Tue, 05/04/2010 - 10:10
If you're accesing an application via an IPsec tunnel, you should see the following:
sh cry isa sa --> will display the status of phase 1 which is going to be Active or QM_IDLE
sh cry ips sa --> will disply the SAs for each pair of subnets communicating through the tunnel
If you don't get any output, perhaps the communication is taking place without going through the tunnel?
Federico.
