Distributed EtherChannel
I know I can use Link Aggregation 802.3ad on a single switch, however can I create a link between two switches and use a port from each switch in the etherchannel group?  This feature is similar to HP's new distributed trunking which does this very thing.  I have two 6509 switches and all of my HP servers have 2 NICs.  I would like to make it so that if a NIC or switch dies then communications keep working.
Jon Marshall Tue, 05/04/2010 - 10:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
You can do this on -
1) 3750 switches using multichassis etherchannel
2) 6500 switches using VSS
3) Nexus switches using VPCs (Virtual Port Channels)
on all other Cisco switches the ports in the etherchannel must be on the same switch.
Jon
Jon Marshall Tue, 05/04/2010 - 10:27
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon Marshall Tue, 05/04/2010 - 10:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon Marshall Tue, 05/04/2010 - 10:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
Sweet...  So essentially I am just "stacking" two 6500s together.  Thus I could have one uplink on one switch and one on the other back to my building back bone for redundancy.
VSS in effect makes 2 separate 6500 swithes appear as one logical switch to other devices so yes you can have an etherchannel that is spread across both chassis.
Jon
