Ports used by ACS for EAP-TLS
May 4th, 2010
I have an ACS 5.1 appliance, 5508 WLC and APs on what is effectively a DMZ. I need to use EAP-TLS with a Microsoft AD and Microsoft Certificate server which is on the inside of the firewall. What ports do I need to open beween the ACS server and the Microsoft servers ? 443 I assume but anything else ?
Robert.N.Barrett_2 Tue, 05/04/2010 - 18:32
  • Bronze, 100 points or more
From what  I can see in the ACS 5.1 user guide:
If there is a firewall between ACS and AD, certain ports need to be  opened in order to allow ACS to communicate with AD. The following are  the default ports to be opened:
Protocol
Port number
LDAP
389/udp
SMB
445/tcp
KDC
88/tcp
Global catalog
3268/tcp
KPASS
464/tcp
NTP
123/udp
