ACE probing of "virtual hosts" on web servers
ciscocsoc Wed, 05/05/2010 - 01:24
  • Silver, 250 points or more
Have you tried using a scripted probe?
probe scripted USE_HTTP_SCRIPT
         script HTTP_PROBE_SCRIPT "GET http//:www.wibble.com/index.html HTTP/1.0" html 0
Normally with a GET you don't use the absolute URI, but the W3C standard do allow it and all HTTP/1.1 must handle it.  You would need one probe
instance per Virtual Server. Alternatively use the provided sample probe and modify it to take additional arguments.
Cathy
ciscocsoc Wed, 05/05/2010 - 08:50
The scripts are documented in the Server Load Balancing Manual.
My understanding is that the scripts provided by Cisco are samples and they are not supported - and AFAIK you can't raise TAC cases against them. If you need authentication then you'll have to work out how to do that using the Tcl methods available - but if you go beyond "basic" authentication it will get very messy very quickly.
It might be easier to have another system (e.g. Nagios) do the probing and setting the contents of a status page on the main server appropriately. Then use can use the HTTPCONTENT probe.
Cathy
Sean Merrow Wed, 05/05/2010 - 09:57
Hello Folks,
I wonder if you could get away with just using the built-in HTTP probe rather than the scripted probe?  With the built-in HTTP probe, you can configure all sorts of HTTP headers, including the Host header which might be all you need for your server hosting multiple sites.
Just to clarify on the support for scripted probes that TAC supports:  If the script is downloaded from cisco.com, and is not modified, then TAC will support it.  It is not supported if it is modified, and TAC will not support custom-created scripts.
Hope this helps,
Sean
