Create Voicemail box without having a physical phone.
ryoung195
Can a voicemail box be created on cisco unity without having a physical phone attached to it.
William Bell
Yes, this is not a problem.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
David Hailey
Yes, you just need a unique extension assigned to it. The user won't get MWI obviously but can call into the system (if configured) and check messages via TUI. If you are interested, there are other options such as SMTP notification, etc. Let me know if you'd like more info.
Hailey
Please rate helpful posts!
Yeah,  if you have more information that would be great.  Thanks
