CUCM 7.x - permissions to manage profiles
Answered Question
May 4th, 2010
What are the minimum admin permissions needed to allow someone to manage extension mobility? The 'PhoneAdministrator' group doesn't quite get me there. I need this person to be able to create device profiles, create DNs, and associate them with end users.
Patrick
Correct Answer by William Bell about 7 years 1 month ago
Patrick,
I had to mock this up in my lab to get an answer for you. The Roles you need to add:
1. Phone Services Subscribe. This is needed if you want to add the EM phone service to Devices and Device Profiles
2. User Web Page. This is needed if you want to edit users so you can assign Device Profiles, phone extensions, etc.
3. Service URL Page. (optional) This is handy if you want to create a Service URL button on the station (i.e. pointing to the EM service)
To get these roles, you can go to User Manager..Roles. Copy the Standard CCM Phone Management role to a new role with a nifty name. Add the above roles (Read + Update) and save. Then you can go to User Manager..Groups. Copy the "Standard CCM Phone Administration" group to a new group with a nifty name. Edit the role assignment. Remove the "Standard CCM Phone Management" role and add your new "nifty role". Save. Assign to target user. Test.
HTH.
Bill
Please remember to rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
William Bell Tue, 05/04/2010 - 18:33
  • Purple, 4500 points or more
Patrick,
HTH.
Bill
hypnotoad Wed, 05/05/2010 - 12:29
Thanks Bill. This is exactly what I needed. I haven't tested it yet but I'm sure I'll be able to work through it.
Patrick
