ā05-04-2010 05:26 PM - edited ā03-19-2019 12:53 AM
Hi Guys
I got question about that UCCX script and abandoned calls , so currently we had 4 different script for support the call follow .
So the Main script is just AA let the people select menu 1 , 2 ,3 then go to different queue , after select 1 (for example) then call-direct to second script trigger number and coming into the queue .
Unfortunately , the system counter the action to be an Abandoned call , I already open the case about this issue and the TAC did not found any configure issue on UCCX , from the log we can seem all the REDIRECT,lrd=5000 is abandoned call .
23811205: Apr 28 13:01:44.257 GMT+800 %MIVR-SS_TEL-7-UNK:Call.received() JTAPICallContact[id=37148,implId=151183/1,state=STATE_RECEIVED_IDX,inbound=true,App name=APP0,task=null,session=null,seq num=-1,cn=5000,dn=5000,cgn=0405554590,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=5000,route=RP[num=5000],TP=null
23811420: Apr 28 13:02:00.491 GMT+800 %MIVR-SS_TEL-7-UNK:Call.transferring(5030) JTAPICallContact[id=37148,implId=151183/1,state=STATE_ANSWERED_IDX,inbound=true,App name=APP0,task=48000040709,session=36000027315,seq num=0,cn=5000,dn=5000,cgn=0405554590,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=5000,route=RP[num=5000],TP=5007]
23811424: Apr 28 13:02:00.491 GMT+800 %MIVR-SS_TEL-7-UNK:Call.abandoned() - transferring JTAPICallContact[id=37148,implId=151183/1,state=STATE_ANSWERED_IDX,inbound=true,App name=APP0,task=48000040709,session=36000027315,seq num=0,cn=5000,dn=5000,cgn=0405554590,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=5000,route=RP[num=5000],TP=5007]
23818414: Apr 28 13:09:46.095 GMT+800 %MIVR-SS_TEL-7-UNK:Call.transferring(239) JTAPICallContact[id=37149,implId=151183/1,state=STATE_ANSWERED_IDX,inbound=true,App name=app2_Admin,task=48000040710,session=null,seq num=-1,cn=5030,dn=5030,cgn=0405554590,ani=null,dnis=null,clid=null,atype=REDIRECT,lrd=5000,ocn=5000,route=RP[num=5030],TP=5034]
23818421: Apr 28 13:09:46.095 GMT+800 %MIVR-SS_TEL-7-UNK:Call.abandoned() - transferring JTAPICallContact[id=37149,implId=151183/1,state=STATE_ANSWERED_IDX,inbound=true,App name=app2_Admin,task=48000040710,session=null,seq num=-1,cn=5030,dn=5030,cgn=0405554590,ani=null,dnis=null,clid=null,atype=REDIRECT,lrd=5000,ocn=5000,route=RP[num=5030],TP=5034]
Please give some advice about that and I am look forward to heard from you guys soon .
ā05-04-2010 06:43 PM
You need to use the Set Call Contact Info step to mark the call as handled if the Call Redirect from one application to the next was successful.
You may want to reconsider transfering the contact across applications and using subflows or a single script if possible.
ā05-04-2010 08:50 PM
Thanks for that I will be try it later today .
could you please send one of example about this kind of script ?
Cheers
ā05-05-2010 05:42 PM
Hi Jon
I was tested "Set Call Contact Info step to mark the call as handled" last night , but not working .
so in the get call contact info properties , I was used last Redirect number to nest trigger number .
but not working .
so have got any idea about that ?
thanks
