Call Trace
Answered Question
May 4th, 2010
Hello
I need to trace incoming call recived by extension in my CM 6.1,
I'm able to do it using the Reports form or using Real time monitor?
Correct Answer by William Bell about 6 years 11 months ago
You can use Real Time Monitor (RTMT) to collect the traces. First, you must ensure that you understand the trace levels. See the following URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_1_1/admin/s...
The trace you are interested in is the Call Manager trace. The default trace level is Error which is useless unless you just want to see errors. I typically set my Call Manager trace level to Significant. I would not recommend using Detailed or Arbitrary unless you are setting it temporarily and/or under Cisco Tac recommendation.
There is a nifty feature called "troubleshooting trace settings" which you may want to read up on:
Once you setup a trace then you can collect it via RTMT. Got to System>Tools>Trace>Trace and Log Central. Look at File Collection or Remote Browse. Remote browse means you can browse the traces that are stored on the server. File Collection means you can download the files locally and figure things out. You can also use "Real Time Trace" but it is anything but real time.
HTH.
Bill
Correct Answer by Jonathan Schulenberg about 6 years 11 months ago
Cisco UCM CDR will show a call record for the on-net call information. You would need to work with your telephony provider to trace it beyond the edge of your network. Note tha the Malicious Call ID feature may provide you some additional functionality depending on what is happening.
Overall Rating: 5 (4 ratings)
Correct Answer
Jonathan Schulenberg Tue, 05/04/2010 - 18:35
  • Cisco Designated VIP,
    2017 IP Telephony
Correct Answer
William Bell Tue, 05/04/2010 - 18:47
  • Purple, 4500 points or more
HTH.
Bill
INFOTEP_OFN Wed, 05/05/2010 - 07:12
Hello
Thanks for your answer, but the trace that i would like to do is from especific extension, all the recived calls from insisde the network and from the pstn.
thanks
William Bell Wed, 05/05/2010 - 07:23
Understood. The CM traces I provided will get you both internal and external call setup information to the phone.
Bill
