Definition of log entry: %IPFFT-W-SFFTREDYELLOW:
May 4th, 2010
We have a switch stack with 4 switches (SGE2000 and SGE2000P) and we are seeing the log messages below filling up the logs. Can one of the Linksys engineers please provide a definition of the %IPFFT-W-SFFTREDYELLOW log message?
We have not seen this message on other SGE switch stacks with very similar configurations.
Log Index Log Time Severity Description   2147483334  19-Apr-2010 14:00:34    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.10.37, mask - 255.255.255.255, entry_num - 199          2147483336  19-Apr-2010 13:59:55    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.5.80, mask - 255.255.255.255, entry_num - 199          2147483337  19-Apr-2010 13:59:25    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.11.36, mask - 255.255.255.255, entry_num - 199          2147483338  19-Apr-2010 13:58:56    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.12.108, mask - 255.255.255.255, entry_num - 199          2147483339  19-Apr-2010 13:58:20    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.12.52, mask - 255.255.255.255, entry_num - 199          2147483342  19-Apr-2010 13:57:49    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.12.64, mask - 255.255.255.255, entry_num - 199          2147483343  19-Apr-2010 13:57:19    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.3.18, mask - 255.255.255.255, entry_num - 199          2147483344  19-Apr-2010 13:56:49    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.156.33, mask - 255.255.255.255, entry_num - 199          2147483345  19-Apr-2010 13:56:04    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.10.30, mask - 255.255.255.255, entry_num - 199          2147483347  19-Apr-2010 13:55:34    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.10.113, mask - 255.255.255.255, entry_num - 199          2147483348  19-Apr-2010 13:55:04    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.12.250, mask - 255.255.255.255, entry_num - 199          2147483349  19-Apr-2010 13:54:34    Warning  %IPFFT-W-SFFTREDYELLOW: IP SFFT RED YELLOW: ip caused the problem:  fft_num - 1, mrid - 1, ip - 192.168.10.18, mask - 255.255.255.255, entry_num - 199
Thank you.
steve.mccann Thu, 05/13/2010 - 16:49
Hi Andrew,
I have already opened a case for this, but apart from our initial contact from your support staff, all my follow up emails have been ignored. No case number was given either. Our account manager advised posting it here.
Cheers,
Steve
MARKUS RADTKE Thu, 12/30/2010 - 06:21
Hi Steve,
my customer has exactly the same error messages. Do you have news concerning these messages?
Markus
alissitz Mon, 01/03/2011 - 13:09
  • Silver, 250 points or more
I do not recall getting an answer for the specific logs ... just a suggestion to call support and get a RMA.  Your case may be different though ...
Have you all tried support?
steve.mccann Mon, 01/03/2011 - 13:36
Hi Markus,
No, unfortunately the cause of this was never determined. It hasn't happened again since.
It's quite surprising that no one at Cisco could give us a definition for their own syslog messages.
Cheers,
Steve
alissitz Mon, 01/03/2011 - 14:18
Understood.
Just curious, did you get a RMA or anything?
If you like, you can call back in and ask for an escalation.  HTH,
Andrew
steve.mccann Mon, 01/03/2011 - 14:37
Hi Andrew,
An RMA was offered back when we originally logged the call, but we weren't interested in wasting the time required to replace the hardware if Cisco couldn't tell us that it was actually a hardware fault. (this was a stack, not an individual switch). And so far the problem hasn't occurred again which suggests we made the right choice.
The underlying issue is that no one at Cisco could give us a definition of the above log message. If we knew what it meant, we (and Cisco) would be in a better position to determine whether replacing the hardware would actually fix any problem or whether it is a software fault.
Steve
mpyhala Wed, 02/23/2011 - 16:34
  • Gold, 750 points or more
Steve,
I have located some information about the error you saw in the switch.
This message is not an error, it is just an informational message related to directly connected hosts in the ARP table. The switch keeps a list of directly connected hosts that is constantly updating. When the switch reaches more than 200 directly connected hosts in the ARP table, this kind of message starts to appear. At this point the switch will clear part of the ARP table in order to keep at most 180 used addresses.
As previously mentioned, this is not causing any problems on the switch. The "ip caused the problem" part is bad phrasing and only means that the table reached the maximum number of addresses. The switch should function fine.
