WLC and NGS WebAuth Certificates
May 4th, 2010
We have a WISM in our Cat6509 switch. We created a CSR and then downloaded the device certificate and intermediate certificate and root certificates from GoDaddy. Then following the Cisco documentation we chained the certificates together and then used TFTP to "download" them to the controllers. That worked great, but for some reascon we are still getting prompted on the client about the certificates.
Kayle Miller Wed, 05/05/2010 - 12:26
My first guess would be 1 of 2 things, #1 - The certificates weren't compiled together correctly; since you have to go thru a funky sequence to create the certificate package that is uploaded to the controller. #2 - The root certificate you used is not present in either the machine or user store of the machines.
jkeddington_2 Wed, 05/05/2010 - 12:36
Thank you very much for you suggestions. We were thinking along the same lines. To give an update it looks like it was related to how the redirection was working. The engineer I am working with stayed late and figured some things out which I am not positive on, but we are now having sporatic issues. With an iPhone we are not prompted at all about certificates and it is working great. If I use a laptop then I am redirected to the WLC (no cert popup) and then redirected to the NGS which does prompt me about the cert. We purchased two certificates from GoDaddy so this is a bit confusing. Looks like we are making progress but still not quite completely working. I will update this thread with any new info.
Trending Topics - Security & Network
