05-04-2010 10:28 PM - edited 03-15-2019 10:37 PM
I can not get my 7914 to show any numbers. I am using 7965G phones with 7914 expansion modules. I am using ccm 4.1, I have the SCCP firmware SP00105000300 (cmterm7914-sccp.5-0-3.exe) loaded on both pub/sub. The phones are using SCCP45.8-4-1SR2S. The phone reconizes the module, (I can change the contrast via 7965G), But none of my speed dials show up on the expansion module. Let me know what you think. Thanks
Solved! Go to Solution.
05-04-2010 11:23 PM
If I recall correctly, you need to do a few things - I think the 3rd option may be what you've missed.
1) Get the firmware fixed up and devices connected (sounds like you're OK here)
2) On the 7965 config page, set Module 1 to the 7914 (not some other 79xx module)
3) In device/device settings/phone button template, copy the Standard 7965 template. Assign each line to the feature you want (e.g. first two lines, then 18 speed dials for example). Save this, then return to the phone config and assign the new phone button template.
Aaron
Please rate helpful posts...
05-04-2010 11:23 PM
Aaron
05-04-2010 11:37 PM
The fix was creating the button template. Thanks for the quick reply
05-04-2010 11:38 PM
Good stuff.
