cisco 3640 cant configure voice-ports
May 5th, 2010
I've an cisco 3640 with a VWIC-2MFT-E1 network module. Can anybody tell me why i cant configure any voice-port? without able to configure voice-port, i cant assign any port for my "dial-peer voice xx pots". Anybody has any solution?
what im trying to do is sending voice data traffic to
controller E1 1/0
framing NO-CRC4
clock source line primary
channel-group 0 timeslots 1-31
interface Serial1/0:0
bandwidth 2048
ip address
ip mtu 300
encapsulation ppp
no ip route-cache
no fair-queue
no cdp enable
dial-peer voice 777 pots
destination-pattern 77T
no digit-strip
forward-digits all
1 vote
forcedgee Wed, 05/05/2010 - 07:38
Thanks for the reply. After reading the data sheet, i got a clearer understanding. It says i need either NM-1FE2W, NM-1FE1R2W, NM-2FE2W to get one serial channel group for my VWIC-2MFT-E1. Am i right? Meaning to say, if i get one of those WIC, im able to create voice ports?
Another question, my 3640 has a WIC which is in used for WAN and a 12 port vlan-switch network module, i understand i need (NM-1FE2W, NM-1FE1R2W, NM-2FE2W) to be able to config voice ports on VWIC-2MFT-E1. Is there any other way to configure to send voice traffic out without voice-port configuration?
Paolo Bevilacqua Wed, 05/05/2010 - 12:45
There is no support for the VWIC-2MFT-E1 on a 3600.  Support is available for the VWIC-2MFT-E1-DI, but with one serial channel group.
That is incorrect. See:
table "Cisco ICS 7750, 36xx, 37xx, and 38xx Platforms Matrix"
In any case, the 3600 is too old for effiencient voip, but use something newer instead.
carunach Wed, 05/05/2010 - 10:10
For E1 PRI voice configuration, we will need to configure "pri-group" under the E1 controller :
Please refer to the following URL :
Please note that 3600 is End of Life :
forcedgee Wed, 05/05/2010 - 19:24
I've only got this from my controller E1
Controller configuration commands:
  channel-group     Specify the timeslots to channel-group mapping for an
  clock             Specify the clock source for a DS1 link
  default           Set a command to its defaults
  description       Controller specific description
  detect            Enable detection of loopback request
  exit              Exit from controller configuration mode
  framing           Specify the type of Framing on a E1 link
  guard-timer       Guard timer (0-20) for xcsp calls - timer duration and
                    accept/reject on expiry
  help              Description of the interactive help system
  line-termination  Specify the line termination for E1
  linecode          Specify the line encoding method for a E1 link
  loopback          Put the entire E1 line into loopback
  mode              Configure the controller mode
  no                Negate a command or set its defaults
  shutdown          Shut down a E1 link (send Blue Alarm)
  tdm-group         Configure DS0 group for TDM
Do i need DSP for the voice-ports? Please guide me on what more module i need to get. Thanks!!;jsessionid=AF45FBC0DDB8636D70F9B526A367016F.node0
carunach Thu, 05/06/2010 - 00:57
Yes, we will need DSP(s) to enable voice functionality.
Please use NM-HDV, VWIC-2MFT-E1 and PVDM modules for E1 PRI in Cisco 3640 :
Also, if this router is for production network please note that Cisco 3640 is End of Life / Support. For production use, please consider ISR (18xx/28xx/38xx) or ISR-G2 (19xx/29xx/39xx).
Leo Laohoo Thu, 05/06/2010 - 15:34
I have no idea with what you are designing or what you are achieving but I can tell you this:  I will never, ever, design  voice/fax systems built around a 3600:  It's too slow for current VoIP and hardware support is very difficult.
Supporting a legacy system would be financially un-sound.
Related Content
