cisco ips register value
May 5th, 2010
Hi All
              I have cisco IPS 4200 series and each time when I reboot then it stuck into rommon mode. I think its register value is to be changed. can anyone tell me the default config register value so that it doesnt stuck into rommon mode again.
Taran
Jennifer Halim Mon, 05/10/2010 - 01:01
IPS normally goes to rommon mode if you hit the Break or ESC key on the console. You might want to double check if either the Break or ESC key might be stuck by any chance.
Otherwise, I would recommend that you reimage the IPS appliance to the latest software release.
