Maximum File size on DMP
May 5th, 2010
Is there a maximum file size that DMP 4400G can support. We are trying to upload a 7GB MPEG file to the DMP with an attached 16Gb USB flash drive. However, it fails when it reaches 56% with an FTP error: ( "Unable to write data to the transport connection: An existing connection was
forcibly closed by the remote host.")
Is there a maximum file size that the DMP FTP daemon supports?
Tomas De Leon Wed, 05/05/2010 - 12:26
  • Cisco Employee,
I am not aware of any File size limitations in the DMP.
I tested with DMP-4400G running 5.2.
I created a 7GB file and used FTP (Filezilla) to upload file to
USB2 on the DMP.
The file transfered without issue.
I would suggest trying a different file and test
transfer again.
For Example:
(linux, OS X, unix)
command = dd
dd - create a large file for testing
Description
To create a 7 GB file:
# dd if=/dev/zero of=file_7GB bs=7m count=1k
Example
* What FTP client are you using?
* What format type is file?
* What version of code on the DMP?
* What file format is used on the external USB drive?
* What manufacturer & model# of the flash being used?
T.
sharpgate Wed, 05/05/2010 - 14:04
Thanks Tomas for your thorough response.
I will do more testing as you advised and get back with the answers to your questions.
