LMS 3.2 - DFM Notification Services issue
Answered Question
May 5th, 2010
  • Silver, 250 points or more
My customer installed an LMS 3.2 on Windows 2008 Server with SP1.
Now the DFM Notification Services causing Problems.
We configured for a test the Event Set A and setup a Notification group with the following boxes ticked:
Alert Severity
Critical   Informational
Alert Status
Active
Event Selection
Event Set: A
Event Severity
Event Status
Active
And all Devices marked in the device selector.
At least the E-Mail configuration was set.
Now none of the Alerts or Events generate an automated e-mail, while the manual mailing from the AAD is working.
I restarted the LMS dmgtd and founf the following lines in the DFMLogServer.log:
05/May/2010 10:39:46:473 ERROR  ? ?  - Exception in registry server java.net.BindException: Address already in use: JVM_Bind
05/May/2010 10:40:16:220 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:40:16:222 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:40:16:223 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:40:26:262 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:40:26:263 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
In the nos.log is see the following:
05-May-2010|10:55:16.370|ERROR|NOS|Process EPM Data Thread:Pooled Thread:1|EpmDataQueueItem|processEPMData()|.|Caught Exception in processEPMData(): java.util.NoSuchElementException
While the NOSServer.log is showing the following:
05/May/2010 10:41:05:973 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:41:05:981 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:41:05:983 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
    at com.cisco.nm.xms.ctm.client.CTMCall.establishIPC(CTMCall.java:238)
    at com.cisco.nm.xms.ctm.client.CTMCall.<init>(CTMCall.java:218)
    at com.cisco.nm.xms.ctm.client.CTMClientProxy.<init>(CTMClientProxy.java:64)
    at com.cisco.nm.xms.ctm.client.CTMClientProxy.getProxy(CTMClientProxy.java:180)
    at com.cisco.nm.xms.ogs.client.OGSServerProxy.init(OGSServerProxy.java:179)
    at com.cisco.nm.xms.ogs.client.OGSServerProxy.init(OGSServerProxy.java:98)
    at com.cisco.nm.xms.ogs.client.OGSServerProxy.<init>(OGSServerProxy.java:85)
    at com.cisco.nm.trx.nos.server.EPMPoller.ogsVerifyService(EPMPoller.java:212)
    at com.cisco.nm.trx.nos.server.EPMPoller.<init>(EPMPoller.java:144)
    at com.cisco.nm.trx.nos.server.NOSServer.initializeEPMPoller(NOSServer.java:244)
    at com.cisco.nm.trx.nos.server.NOSServer.<init>(NOSServer.java:107)
    at com.cisco.nm.trx.nos.server.NOSServer.main(NOSServer.java:259)
05/May/2010 10:41:35:995 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:41:35:997 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:41:35:998 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:42:06:008 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:42:06:009 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:42:06:009 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:42:36:018 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:42:36:019 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:42:36:021 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:43:06:028 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:43:06:029 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:43:06:030 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:43:36:038 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:43:36:039 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:43:36:040 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:44:06:050 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:44:06:051 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:44:06:053 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:44:36:064 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:44:36:065 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:44:36:066 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:45:06:075 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:45:06:076 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/May/2010 10:45:06:077 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
    at java.util.StringTokenizer.nextToken(StringTokenizer.java:332)
    at com.cisco.nm.trx.nos.server.ProcessEPMDataManager$EpmDataQueueItem.formatAlertDataOnly(ProcessEPMDataManager.java:789)
    at com.cisco.nm.trx.nos.server.ProcessEPMDataManager$EpmDataQueueItem.processAlertData(ProcessEPMDataManager.java:951)
    at com.cisco.nm.trx.nos.server.ProcessEPMDataManager$EpmDataQueueItem.processEPMData(ProcessEPMDataManager.java:1319)
    at com.cisco.nm.trx.nos.server.ProcessEPMDataManager$EpmDataQueueItem.run(ProcessEPMDataManager.java:206)
    at com.cisco.nm.trx.nos.server.ThreadPool$1.run(ThreadPool.java:37)
And in the dcrclient.log i noticed this:
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:2
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - backed up registry = {47001=[dmserver-RMELogLevelChange, EssentialsDM]}
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - RegistryHandler.addCTMPort returning port = 47002
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:4
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Added urn inventory.ics.server-RMELogLevelChangeat port 47002
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - backed up registry = {47002=[], 47001=[dmserver-RMELogLevelChange, EssentialsDM]}
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - backed up registry = {47002=[inventory.ics.server-RMELogLevelChange], 47001=[dmserver-RMELogLevelChange, EssentialsDM]}
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - RegistryHandler.addCTMPort returning port = 47003
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Added urn archive.service-RMELogLevelChangeat port 47003
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - backed up registry = {47003=[], 47002=[inventory.ics.server-RMELogLevelChange], 47001=[dmserver-RMELogLevelChange, EssentialsDM]}
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] INFO com.cisco.nm.dcr.DCRContext - Settings File: E:/LMS\lib\classpath\com\cisco\nm\dcr/dcr.ini
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG com.cisco.nm.dcr.DCRSystem - In Instantiating DCR Subsystems...
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:1
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG com.cisco.nm.dcr.DCRDatabaseAccess -  Query is UPDATE JRM set command= '$JP -cw:jre lib\jre -cp MDC\tomcat\common\lib\activation.jar;objects\db\java\smtp.jar;MDC\tomcat\common\lib\mail.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\dcrimpexp.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-client.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-util.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-server.jar;MDC\tomcat\webapps\cwhp\WEB-INF\classes;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\struts.jar;MDC\tomcat\shared\lib\MICE.jar;MDC\tomcat\shared\lib\NATIVE.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\log4j.jar;MDC\tomcat\shared\lib\xerces.jar;MDC\tomcat\common\lib\servlet.jar;MDC\jre\lib\ext\trust.jar;MDC\jre\lib\ext\jcert.jar;MDC\jre\lib\ext\jnet.jar;MDC\jre\lib\ext\trust.jar;MDC\jre\lib\ext\jsse.jar;MDC\jre\lib\ext\store.jar;lib\classpath;www\classpath $JJ com.cisco.nm.dcr.impexp.DCRJobInvoker $JI' WHERE type_id = 'DCR Import Export';
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG com.cisco.nm.dcr.DCRDataManagement - Attribute type details feteched from database
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG com.cisco.nm.dcr.DCRSystem - DCR Subsystems intialized sucessfully
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG CTM.client - Urn:"DCRCAM" Host:EGEER00AS64 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] INFO CTM.client - Establishing RPC
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG CTM.client - Secure Connection is set to TRUE in CTMClientProperties
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG CTM.client - Port specified in CTMClientProperties is 80
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG CTM.client - The newly formed URL is https://EGEER00AS64:443/cwhp/CTMServlet
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG CTM.client - Urn:"LocalDCR" Host:EGEER00AS64 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-16] DEBUG CTM.client - RPC, EncodingStyle = CTMConstants.CTM_BINARY
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-21] DEBUG CTM.Registry - Server Start Check Passed For 47002
[ Wed May 05 10:40:15 CEST 2010 ] [Thread-21] DEBUG CTM.Registry -  server running at 47002
[ Wed May 05 10:40:16 CEST 2010 ] [Thread-22] DEBUG CTM.Registry - Server Start Check Passed For 47003
[ Wed May 05 10:40:16 CEST 2010 ] [Thread-22] DEBUG CTM.Registry -  server running at 47003
[ Wed May 05 10:40:17 CEST 2010 ] [main] INFO com.cisco.nm.dcr.DCRContext - Settings File: E:/LMS\lib\classpath\com\cisco\nm\dcr/dcr.ini
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG com.cisco.nm.dcr.DCRSystem - In Instantiating DCR Subsystems...
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG com.cisco.nm.dcr.DCRDatabaseAccess -  Query is UPDATE JRM set command= '$JP -cw:jre lib\jre -cp MDC\tomcat\common\lib\activation.jar;objects\db\java\smtp.jar;MDC\tomcat\common\lib\mail.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\dcrimpexp.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-client.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-util.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-server.jar;MDC\tomcat\webapps\cwhp\WEB-INF\classes;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\struts.jar;MDC\tomcat\shared\lib\MICE.jar;MDC\tomcat\shared\lib\NATIVE.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\log4j.jar;MDC\tomcat\shared\lib\xerces.jar;MDC\tomcat\common\lib\servlet.jar;MDC\jre\lib\ext\trust.jar;MDC\jre\lib\ext\jcert.jar;MDC\jre\lib\ext\jnet.jar;MDC\jre\lib\ext\trust.jar;MDC\jre\lib\ext\jsse.jar;MDC\jre\lib\ext\store.jar;lib\classpath;www\classpath $JJ com.cisco.nm.dcr.impexp.DCRJobInvoker $JI' WHERE type_id = 'DCR Import Export';
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG com.cisco.nm.dcr.DCRDataManagement - Attribute type details feteched from database
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG com.cisco.nm.dcr.DCRSystem - DCR Subsystems intialized sucessfully
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG CTM.client - Urn:"DCRCAM" Host:EGEER00AS64 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed May 05 10:40:17 CEST 2010 ] [main] INFO CTM.client - Establishing RPC
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG CTM.client - Secure Connection is set to TRUE in CTMClientProperties
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG CTM.client - Port specified in CTMClientProperties is 80
[ Wed May 05 10:40:17 CEST 2010 ] [main] DEBUG CTM.client - The newly formed URL is https://EGEER00AS64:443/cwhp/CTMServlet
[ Wed May 05 10:40:17 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:1
[ Wed May 05 10:40:19 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:1
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - Invoked method   class com.cisco.nm.trx.tis.server.TISServiceImpl::getAllDeviceStatusSuccessfully
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - After executecall now
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - method executed
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - response sent
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - came in handleRequest
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - Header read
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - Got a closeconnection from client
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] INFO CTM.server - ClientEntry requestID:1273048820494 is deleted. hashtable size:0
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-8] DEBUG CTM.server - Will now close the TCPChannel
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-7] INFO com.cisco.nm.dcr.DCRContext - Settings File: E:/LMS\lib\classpath\com\cisco\nm\dcr/dcr.ini
[ Wed May 05 10:40:20 CEST 2010 ] [Thread-7] DEBUG com.cisco.nm.dcr.DCRSystem - In Instantiating DCR Subsystems...
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG com.cisco.nm.dcr.DCRDatabaseAccess -  Query is UPDATE JRM set command= '$JP -cw:jre lib\jre -cp MDC\tomcat\common\lib\activation.jar;objects\db\java\smtp.jar;MDC\tomcat\common\lib\mail.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\dcrimpexp.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-client.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-util.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ogs-server.jar;MDC\tomcat\webapps\cwhp\WEB-INF\classes;MDC\tomcat\webapps\cwhp\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\struts.jar;MDC\tomcat\shared\lib\MICE.jar;MDC\tomcat\shared\lib\NATIVE.jar;MDC\tomcat\webapps\cwhp\WEB-INF\lib\log4j.jar;MDC\tomcat\shared\lib\xerces.jar;MDC\tomcat\common\lib\servlet.jar;MDC\jre\lib\ext\trust.jar;MDC\jre\lib\ext\jcert.jar;MDC\jre\lib\ext\jnet.jar;MDC\jre\lib\ext\trust.jar;MDC\jre\lib\ext\jsse.jar;MDC\jre\lib\ext\store.jar;lib\classpath;www\classpath $JJ com.cisco.nm.dcr.impexp.DCRJobInvoker $JI' WHERE type_id = 'DCR Import Export';
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG com.cisco.nm.dcr.DCRDataManagement - Attribute type details feteched from database
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG com.cisco.nm.dcr.DCRSystem - DCR Subsystems intialized sucessfully
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG CTM.client - Urn:"DCRCAM" Host:EGEER00AS64 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] INFO CTM.client - Establishing RPC
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG CTM.client - Secure Connection is set to TRUE in CTMClientProperties
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG CTM.client - Port specified in CTMClientProperties is 80
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG CTM.client - The newly formed URL is https://EGEER00AS64:443/cwhp/CTMServlet
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.common - classLocation is: jar:file:/E:/LMS/MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar!/com/cisco/nm/xms/ctm/common/CTMConfig.class
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - LocalUrnPort recd = 40053
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - Optimization =  true
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-7] DEBUG CTM.client - RPC, EncodingStyle = CTMConstants.CTM_BINARY
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - Returning result of invoke
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - Urn:"LocalDCR" Host:EGEER00AS64 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] INFO CTM.client - Establishing RPC
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - Secure Connection is set to TRUE in CTMClientProperties
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - Port specified in CTMClientProperties is 80
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - The newly formed URL is https://EGEER00AS64:443/cwhp/CTMServlet
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-16] DEBUG CTM.client - RPC, EncodingStyle = CTMConstants.CTM_BINARY
[ Wed May 05 10:40:21 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:1
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] DEBUG CTM.common - classLocation is: jar:file:/E:/LMS/MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar!/com/cisco/nm/xms/ctm/common/CTMConfig.class
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] INFO CTM.server - Publishing with urn:"inventory.ics.server-RMELogLevelChange"
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] DEBUG CTM.Registry - port:47001 urn:"inventory.ics.server-RMELogLevelChange"
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] INFO CTM.Registry -  Waiting to read the data ...
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:4
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Sever is Alive ! Socket[addr=localhost/127.0.0.1,port=47002,localport=32440]
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-0] ERROR CTM.Registry - DUPLICATE_URN,CTMRegistry::addNewURNEntry(): URN already in use
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-0] ERROR CTM.Registry - CTMRegistryResponse FAILED
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] ERROR CTM.Registry - CTMRegistryClient::addNewURNEntry  URN : inventory.ics.server-RMELogLevelChange ErrMsg : URN already in use
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] DEBUG CTM.server - Duplicate urn inventory.ics.server-RMELogLevelChange
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-16] ERROR CTM.server - CTMRegistryClient::addNewURNEntry  URN : inventory.ics.server-RMELogLevelChange ErrMsg : URN already in use
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - Incoming request type is:2
[ Wed May 05 10:40:22 CEST 2010 ] [Thread-0] DEBUG CTM.Registry - backed up registry = {47003=[archive.service-RMELogLevelChange], 47002=[inventory.ics.server-RMELogLevelChange], 47001=[dmserver-RMELogLevelChange, EssentialsDM]}
I attached the output of pdshow command.
What is causing these Problem? A corrupt database or some invalid setting??
Does anybody has an idea?
Thanks in advance
Frank
Correct Answer by Joe Clarke about 7 years 1 month ago
They left out the most important file, nos.jar.  Have your engineer send you this file, and the instructions to install it.  Restart Daemon Manager, and you should be set.
Overall Rating: 5 (2 ratings)
Joe Clarke Wed, 05/05/2010 - 20:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Looks like you are seeing CSCtg43956.  If you contact TAC, you can get a patch which will correct this problem.
frankzehrer Mon, 05/10/2010 - 06:58
Hi Joe,
this did not solve the problem.
I did some further crawling through the logs and saw the follwoing in the EPMServer.log after the serverstartup:
... loads of urn_not_found messages to be ignored during LMS startup
... init of the DFM groups
Groupname retreived at startup is:[email protected]
Groupname retreived at startup is:[email protected]/All Devices
Groupname retreived at startup is:[email protected]/Normal Devices
Groupname retreived at startup is:[email protected]/Pre-deployed
Groupname retreived at startup is:[email protected]/User Defined Groups
java.lang.NullPointerException
    at com.cisco.nm.trx.epm.providers.alarm.AlarmUpdateListener.processUpdatedAlarm(Unknown Source)
    at com.cisco.nm.trx.epm.providers.alarm.AlarmUpdateListener.run(Unknown Source)
    at java.lang.Thread.run(Thread.java:595)
i do not have any clue what causes these NullPointerExceptions.
Maybe you can give ma a hint??
Thanks a lot for your help so fra.
Best regards,
Frank
Joe Clarke Mon, 05/10/2010 - 07:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What patch files did you apply, and what process did you perform to apply them?  I still think your problem is related to the aforementioned bug.
frankzehrer Mon, 05/10/2010 - 22:04
Hi Joe,
thanks for your fast reply.
The corresponding SR is 614309645.
These are the TAC provided files and sizes.
05/06/2010 10:46 AM 1,731  ProcessEPMDataManager$EpmDataQueueItem$epmAlarmHistory.class
05/06/2010 10:46 AM 1,391  ProcessEPMDataManager$EpmDataQueueItem$epmConditionHistory.class
05/06/2010 10:46 AM 889  ProcessEPMDataManager$EpmDataQueueItem$epmEventProperties.class
05/06/2010 10:46 AM 33,774  ProcessEPMDataManager$EpmDataQueueItem.class
05/06/2010 10:46 AM 7,112  ProcessEPMDataManager.class
The setup instruction from TAC:
1- Stop the  daemon manager:
             net stop crmdmgtd
2- Go  to:
$NMSROOT/MDC/tomcat/webapps/triveni/WEB-INF/classes/com/cisco/nm/trx/nos/server
and backup  the original files (either copy them to another safe directory or rename them to  something like . Please don't retain the  original extension when renaming the files.
3- Make  sure that the patch files have the following MD5s:
MD5  (ProcessEPMDataManager$EpmDataQueueItem$epmAlarmHistory.class) =  08851732b0b3aac5bb0636cc3e8e3c10
MD5  (ProcessEPMDataManager$EpmDataQueueItem$epmConditionHistory.class) =  7933e55abb6ad604aa6ca8d3126ff189
MD5  (ProcessEPMDataManager$EpmDataQueueItem$epmEventProperties.class) =  af3b72952ec59d59e30b0309af80a9d2
MD5  (ProcessEPMDataManager$EpmDataQueueItem.class) =  a70f49f8eab6bdea007b4ddd79e3809f
MD5  (ProcessEPMDataManager.class) =  a6ec024955bb638d8fec47694816a82a3-
4- Replace  the originals in the above mentioned directory with these  versions.
5 Start the  Daemon manager:
             net start crmdmgtd
I followed these instructions and still facing the problem.
I also searched for the libeay32.dll and ssleay32.dll, i found them, but in a path not included in the Windows PATH variable. Therefore these files should not influence LMS.
In the NOS Log i still see these messages:
10-May-2010|15:01:10.027|ERROR|NOS|Process EPM Data Thread:Pooled  Thread:1|EpmDataQueueItem|processEPMData()|.|Caught Exception in  processEPMData():  java.util.NoSuchElementException
10-May-2010|15:01:39.747|DEBUG|NOS|Thread-5|EPMPoller|pollEPM_Wash|.|Inside  pollEPM_Wash
10-May-2010|15:01:39.747|DEBUG|NOS|Thread-5|EPMPoller|pollEPM_Wash()|.|!!  _pollStarted =  true
10-May-2010|15:01:39.747|DEBUG|NOS|Thread-5|NOSUtil|sendNotifOnStart|.|0
10-May-2010|15:01:39.747|DEBUG|NOS|Thread-5|EPMPoller|pollEPM_Wash()|.|No  DB Exception in  polling
Since these Messages depends on EPM Data i had a look into the EPMServer.log and EPM.log
The EPMServer.log is shortened and showing all entries from the last dmgtd start. After the usual urn_not_found messages and the init of the Groups the following entry is generated:
After that i changerd the logging of EPM to debug and attached the file as EPM_Debug.zip to this post.
Thanks a lot for your valuable support so far.
Cheers Frank
Correct Answer
Joe Clarke Mon, 05/10/2010 - 22:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
frankzehrer Tue, 05/11/2010 - 02:17
Hi Joe,
the missing jar file did the trick.
Many thanks for your support and have a great day.
Cheers Frank
