Trouble with 4305G firmware/kernel update
Answered Question
May 5th, 2010
Hi forum,
I've searched this forum for similar case, but could not find answer.
I have firmware and kernel update files for the DMP 4305G (5.2.0_FCS_4305.fwimg & DMPkernel_A2_4305.tivella) and tried every known way to me, to upgrade the DMP but without success.
We have DMS 5.2. I've tried upgrading through the DMM, /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} DMM-DSM and even with IIS web server which i found as way to upgrade on this forum, but still no joy.
To be more specific, the try with the IIS web server, I uploaded the file to the root folder and used this example below:
(http://10.10.10.2:7777/set_param?mng.command=start+upgrade+kernel+http://10.10.10.10/DMPkernel_A1_4300.tivella) I only got an window to enter the username and password of the DMP and afterwards  nothing happend.
I have double checked that the DMP has the IP address of the DMM in Centralized Management, DMM-DSM Server timeout set to 300 sec, DMP Web account same as the user/pass in DMM, DMP Service account same user/pass and FTP enabled also.
The odd thing is that in DMM, it shows the 4305G as registered for a while, but after some time it registers out, and the status changes to red X . For this brief period i tired to upgrade the DMP from the Action drop-down menu though it did not do anything.
I know that the kernel should be aplied first and then the firmware. For sake of argument, I've upgraded the 4400G firmware through the DMM with no problem at all.
The exact model name is: DMP-4305G-5.1-K9
If you need me to upload and/or add additional info to this question, do tell.
Any input will be much appriciated!
Tiberie
Correct Answer by Tomas De Leon about 7 years 1 month ago
Ok, I tested a DMP-4305G here that was on 5.0.
I upgraded for 5.0 to 5.1 first.  The upgrade was successful.
I then upgraded for 5.1 to 5.2.  The upgrade was successful.
You may need to capture a sniffer trace to see what is
going on.  And use the same steps and legends that i use
to verify everything in your setup.
T.
RECREATE NOTES:
DMP        = 10.10.10.10
WEB Server = 20.20.20.20
      User = admin
  Password = default
Web Server = Apache (I do not use IIS)
5.1 Web Server Directory = Software/dms-images/DMP-images/5.1/
5.1 Firmware Kernel file = DMPkernel_A1_4305.tivella
5.2 Web Server Directory = Software/dms-images/DMP-images/5.2/FCS/5.2.0_FCS_4305/
5.2 Firmware Kernel file = DMPkernel_A2_4305.tivella
*** UPGRADE KERNEL FROM 5.0 to 5.1 ***
STEP#1
http://admin:[email protected]:7777/get_param?p=sinfo.version
sinfo.version T_STRING Linux version 2.4.22 ([email protected]) (gcc version 3.3.2) #1 Fri Oct 19 11:00:01 PDT 2007
STEP#2
http://admin:[email protected]:[email protected][email protected]_4305.tivella
STEP#3
http://admin:[email protected]:7777/get_param?p=init.upg*
init.upg_context T_STRING Upgrade  (kernel) succeeded
init.upg_percent T_LONG 0
init.upg_status T_STRING Firmware upgrade not active
STEP#4
sinfo.version T_STRING Linux version 2.4.22 ([email protected]-desktop) (gcc version 3.3.2) #1 Tue Nov 18 14:48:57 EST 2008
>> Success Kernel upgraded to 5.1 <<
*** UPGRADE KERNEL FROM 5.1 to 5.2 ***
STEP#1
STEP#2
http://admin:[email protected]:[email protected][email protected]FCS_4305%2FDMPkernel_A2_4305.tivella
STEP#3
STEP#4
sinfo.version T_STRING Linux version 2.4.22 ([email protected]) (gcc version 3.3.2) #1 Wed Dec 9 22:10:26 PST 2009
>> Success Kernel upgraded to 5.2 <<
Overall Rating: 5 (1 ratings)
Tomas De Leon Wed, 05/05/2010 - 07:36
  • Cisco Employee,
If you used the URL that is posted in the note, may not work since certain characters need
to be escaped.
The PREFERRED way to upgrade the kernel images is via
the Digital Media Manager(DMM) - Digital Signage Module(DSM).
Follow the Normal instructions for Upgrading DMP Firmware via
the DMM-DSM and Make sure to CHECK the "Is Kernel Upgrade?"
CheckBox.
Of Course, there may be some standalone or lab DMPs that may need
to upgrade the kernel images without access to a DMM.
To do this you can upgrade the Kernel via ALTERNATE METHOD:
1. HTTP Browser Commands
The Following Method are NOT the recommended method but is a way to upgrade
Kernel without a DMM.
METHOD: HTTP Browser Commands
* FTP or COPY the 5.1 KERNEL image to a REACHABLE WEB SERVER.  HTTP to the WEB SERVER location of the
  Kernel image to verify the image is there and accessible.  Record the IP ADDRESS of the Web Server,
  Location of the File on the Web Server, and the Kernel Image Filename.
  ie. http://web.server.com/DMPkernel_A1_4305.tivella
NOTE: The Image file is in the ROOT directory of Web Server.  If you have in a different
directory the "/" separators (or any Special Characters) will need to be ESCAPED.
* Open Browser and Send the Following HTTP REQUEST to DMP
  http://admin:[email protected]:[email protected]server.com%2F%2FDMPkernel_A1_4305.tivella
  admin          = DMP Web Account Username
  default        = DMP Web Account Password
  a.b.c.d        = IP Address of DMP
  web.server.com = FQDN or IP Address of Web Server
* After the upgrade and DMP reboots use this command to check the status:
Sample Response:
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Tiberie Kirijas Thu, 05/06/2010 - 02:46
Hi Tomas,
I've tried again with the DMM - Digital Signage Module(DSM) and with the HTTP method but still no adequate response from the DMP 4305G.
I'm sending in attachment couple of screen shoots just to be more clear for what is going on while i try the procedure.
For the DMM-DSM case, you can see that the 4305G got registerd for a while and had green checkmark (DMP registerd.JPG) which in meantime i tried the procedure for upgrading the kernel. After some period it just lost status (DMP unregistered.JPG).
For the HTTP Web server method, I tried on IIS 6.0 (WebServer.JPG), I HTTP to the WEB SERVER location to verify (http.JPG), checked the status to see what's going on (see Upgrade status.JPG), but the 4305G did not restart at all. It just promt me for confirmation (see Confirmation dialog.JPG).
I tried also resetting to defaults the DMP, and tried it again through the http and got this output when checking update status (Upgrade status_2.JPG) bear in mind that this time the DMP was set to DHCP, hense it got ip address 10.0.10.129. It simply doesn kick start the upgrade process. I even tried with MIME type (plain/text) also for the .tivella extension.
This is the browser command i used:
http://admin:[email protected]:[email protected].10.50%2F%2FD
Any ideas? Am I still missing something..
Thank you,
Tiberie
Tiberie Kirijas Thu, 05/06/2010 - 08:26
Hi Tomas,
I tried now like this:
http://admin:[email protected]:[email protected].10.50%2FWebServer%2FDMPkernel_A2_4305.tivella
- *WebServer is the Home directory.
and like this:
http://admin:[email protected]:[email protected].10.50%2FDMPkernel_A2_4305.tivella
And when I checked the status did it upgrade, it still showed that the "Firmware upgrade has never been done". The DMP did not restart once. It's like it never got the update going.
I even tried this which i found from an earlier similar post: "Adding the MIME-type .tivella extension (as text/plain) in IIS to allow  the upgrade file to be served by the web server." Still no joy here.
Am I still doing it wrong, or there is something with the DMP or firmware image?
Thank you,
Tiberie
Correct Answer
Tomas De Leon Thu, 05/06/2010 - 12:45
  • Cisco Employee,
T.
RECREATE NOTES:
DMP        = 10.10.10.10
      User = admin
  Password = default
STEP#1
STEP#2
STEP#3
STEP#4
STEP#1
STEP#2
STEP#3
STEP#4
Tiberie Kirijas Sat, 05/08/2010 - 05:05
Hi Tomas,
I've tried now with Apache server like you, run Wireshark , got TCP/IP handshake packets back and forth from the server and the DMP, but it did not start the upgrade process. I think there might be something missing(or restricting) from the configuration of the httpd.conf file of the Apache server to PUSH the kernel or maybe I should declare the .tivella type in the mime.types file!?
Can you please send me your httpd.conf file so I compare it and see if there is something different from mine config, if its not a problem?
Thanks a LOT for your continued interest to solve my problem, Tomas!
p.s.
This is what i get from step #1 from the 4305G DMP:
Step #3:
init.upg_context     T_STRING     Firmware upgrade has never been done
init.upg_status     T_STRING     Invalid product tag (act:"", exp:"D4305G").
Sincerely,
Tiberie
Tomas De Leon Sat, 05/08/2010 - 09:42
  • Cisco Employee,
Tiberie,
post me your email and I will send you some additional
instructions to try.
T.
Tiberie Kirijas Sun, 05/09/2010 - 03:48
Hi Tomas,
I've send you my e-mail via private message to you.
Meanwhile, here are mine findings:
I issued the command on the 4305G: https://admin:[email protected]:7777/get_param?p=*.* and the DMP did not respond. That was strange, because before trying with the 4305G, I tried with the 4400 which works flawlessly. Then I removed the S from http(S) and it worked with the 4305G too.
Have in mind that the 4305G is factory reset, I've only changed the password, from default to Passw0rd.
I am sending in attach. the output from the 4400 just for sake of comparison.
Tiberie
Tomas De Leon Sun, 05/09/2010 - 07:13
  • Cisco Employee,
Please check your email.   I sent you additional information to try.
Please try and let me know how it goes.
T.
