Configuring SNMP Traps UCS 6.1.3
May 5th, 2010
Hi, I have some confusion on configuring SNMP and Trap notifications to a network monitoring box we have. When I enter Unified Serviceability and go to SNMP Notification Destination Configuration and try to set up the trap notification, it asks for a community name and does not pick up the one I have already configured called public. If I then create a new community name from that screen called public it says it has created it on nodes that have not had it configured before, this sounds right but it still does not show up in the drop list for me to pick to finish the configuration of the trap.
I am not sure if it is working or not. Can someone help me and maybe show me a way to send it a test trap to verify it is working?
RoyalPlastics Wed, 05/05/2010 - 07:45
Okay I found where the community field will not show up unless it is set to minimum notify privileges. I did that and it appears fine now.
Does anyone know how to send it a sample trap to make sure it works?
