876W Router: internet wired but no wireless internet, need help configuring
Answered Question
May 5th, 2010
For a long time now I try to get my 876 Wireless Router configured but I do not succeed. (I'm just a cisco loving amateur so please respect my poor knowledge)
Problem is that I got the router setup for internet connection but only wired. Now I have a configuration in which I also succeed to make a wireless connection. Only the problem is that the wireless connection does not get to the internet.
Next to some other minor looking problems that will be the main thing!
I tried several helpfull tools as CCP and some sites which gave a Form-template on the internet or a Excel-sheet to fill in. All those did not function for me.
Now I hope there will be someone out there who is willing to have a look at my running-config and give me a helping hand.
Thanks in advance,
Emil
Building configuration...
Current configuration : 6294 bytes
! Last configuration change at 03:55:22 UTC Thu Apr 29 2010 by Router876W
version 15.0
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-1959697149
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1959697149
revocation-check none
rsakeypair TP-self-signed-1959697149
crypto pki certificate chain TP-self-signed-1959697149
certificate self-signed 01
<KEY-FOLLOWS-HERE>
   quit
dot11 syslog
dot11 ssid 876W
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 <MYKEY>
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
username Router876W privilege 15 secret 5 <MYSECRET>
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/48
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers aes-ccm tkip
broadcast-key vlan 1 change 30
ssid 876W
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address <MY-ISPGIVEN-FIX-IPADDRESS> 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username <MYUSERNAME> password 0 <MYPASS>
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Correct Answer by John Blakley about 7 years 2 months ago
Glad to hear it   Sometimes a reboot is all that's needed, especially when nothing else makes sense! LOL! If you would, please rate this post so others can find it if needed.....
Thanks!
John
Overall Rating: 5 (1 ratings)
spremkumar Wed, 05/05/2010 - 07:43
  • Red, 2250 points or more
Once you are connected using the wireless connection are you able to resolve any of the website hostaddress (ex.www.cisco.com), when you try to ping any of the outside world host are you able to see the resolution happening (from the web address to ip address).
You can try pushing the dns server details as part of the dhcp config so that the client pcs can use that dns for resolution.
Your SP might have given the DNS addresses which you can make use of here to get configured under the ip dhcp pool ccp-pool group.
regds
EH1165305 Wed, 05/05/2010 - 08:38
Thank you very much for your support.
Sorry it took some time to answer: there are some weard things happening as I can ping in a dos command but not with terraterm over my usb/serial connection with the router. That also makes that I see differences in my running config which I tried to upload to my computer.
Never mind; although I have internet connection without the DNS in my config, as I see now in my config as you found out, I added ip domain-lookup and ip name servers from my ISP.
Everything stays the same. I can still ping into the world wihtin my DOS prompt but not with my console connection.
And for the Wireless problem: nothing has changed. Still I can connect wireless but I have no internet connection with wireless.
Any other suggestions/ ideas?
spremkumar Wed, 05/05/2010 - 09:47
can you post the output of ipconfig /all when connected to the ethernet and onto the wireless?
are you manually assigning ip address & dns when connecting through the ethernet port ?
regds
EH1165305 Wed, 05/05/2010 - 10:05
Starting with your last question: Yes I assing them manually.
Sorry that I don't know if I have to give my answers in the attachments or just paste them here, but here they are pasted anyhow. The ipconfig is from my Laptop but I also cannot connect with my Iphone which I also give a manual IP / Mask configuration and DNS addresses.
Windows IP-configuratie
   Hostnaam  . . . . . . . . . . . . : Vostro1700
   Primair DNS-achtervoegsel . . . . :
   Knooppunttype . . . . . . . . . . : hybride
   IP-routering ingeschakeld . . . . : nee
   WINS-proxy ingeschakeld . . . . . : nee
Draadloos LAN-adapter voor Wireless Network Connection:
   Mediumstatus. . . . . . . . . . . : medium ontkoppeld
   Verbindingsspec. DNS-achtervoegsel:
   Beschrijving. . . . . . . . . . . : Intel(R) Wireless WiFi Link 4965AGN
   Fysiek adres. . . . . . . . . . . : 00-1F-3B-12-D0-C5
   DHCP ingeschakeld . . . . . . . . : nee
   Autom. configuratie ingeschakeld  : ja
Ethernet-adapter voor Local Area Connection:
   Beschrijving. . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controlle
r
   Fysiek adres. . . . . . . . . . . : 00-1D-09-C4-C1-11
   Link-local IPv6-adres . . . . . . : fe80::a0f6:181e:5de0:93d6%11(voorkeur)
   IPv4-adres. . . . . . . . . . . . : 10.10.10.4(voorkeur)
   Subnetmasker. . . . . . . . . . . : 255.255.255.0
   Standaardgateway. . . . . . . . . : 10.10.10.1
   DHCPv6 IAID . . . . . . . . . . . : 234888457
   DHCPv6-client DUID. . . . . . . . : 00-01-00-01-13-47-2B-61-00-1D-09-C4-C1-11
   DNS-servers . . . . . . . . . . . : 195.121.1.34
                                       195.121.1.66
   NetBIOS via TCPIP . . . . . . . . : ingeschakeld
Tunnel-adapter voor isatap.{4437E7D3-F10B-40A0-A997-8AD3F7C0CD54}:
   Beschrijving. . . . . . . . . . . : Microsoft ISATAP Adapter
   Fysiek adres. . . . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel-adapter voor isatap.{5F991D0E-5E7D-47A5-8C14-ECD88711BD5D}:
   Beschrijving. . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel-adapter voor Teredo Tunneling Pseudo-Interface:
   Beschrijving. . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6-adres. . . . . . . . . . . . : 2001:0:5ef5:73bc:2408:184e:2af5:78bf(voor
keur)
   Link-local IPv6-adres . . . . . . : fe80::2408:184e:2af5:78bf%14(voorkeur)
   Standaardgateway. . . . . . . . . : ::
   NetBIOS via TCPIP . . . . . . . . : uitgeschakeld
Tunnel-adapter voor Reusable ISATAP Interface {4AD2C90B-FD2C-41C7-98E6-6E1DE4977
EE7}:
   Beschrijving. . . . . . . . . . . : Microsoft ISATAP Adapter #4
   Link-local IPv6-adres . . . . . . : fe80::b02d:6dcb:23cc:7d9e%12(voorkeur)
   IPv4-adres. . . . . . . . . . . . : 10.10.10.3(voorkeur)
   DHCPv6 IAID . . . . . . . . . . . : 218111803
                                       195.121.1.66
r
EE7}:
Message was edited by: Emil Heilbron Sorry messed it up in copying. Now it is right.
John Blakley Wed, 05/05/2010 - 12:41
  • Purple, 4500 points or more
Try this:
bridge irb
You'll want to remove the address from vlan 1 and add the internal address that's assigned to the vlan to the bvi:
int bvi1
ip nat inside
Then add:
int vlan 1
bridge-group 1
HTH,
John
paolo bevilacqua Wed, 05/05/2010 - 13:04
  • Hall of Fame,
    Founding Member
That is not neded, because OP has PPP, not PPPoE.
EH1165305 Wed, 05/05/2010 - 13:12
Sorry, need to reply to John
John Blakley Wed, 05/05/2010 - 13:14
You'll need to enable bridging first:
bridge irb
That should create your bvi interface.....
John
EH1165305 Wed, 05/05/2010 - 13:23
So I leaf the thing whit ip tcp adjust-mss out as Bevilacqua suggested.
And I made the bridge with your bridge irb command which gives me a next error:
yourname(config-if)#ip address  10.10.10.1 255.255.255.0 % 10.10.10.0 overlaps with Vlan1
How to get rid of that please ..
John Blakley Wed, 05/05/2010 - 13:25
You need to remove the ip address from the vlan interface first:
int vlan 1
no ip address
bridge-group 1
int bvi1
EH1165305 Wed, 05/05/2010 - 13:46
Oops. I did as you guys suggested. But now it is not possible anymore to ping from Laptop to router, nor is it possible from console to ping to internet. So all connections are gone. Good luck I have a funtioning not wireless 876 to still connect.
Any suggestions what went wrong? And even how to solve this even bigger problem
So what I did is the combination of your advices. Toke away the Vlan 1 and added the bridge with the same 10.10.10.10/ 24
John Blakley Wed, 05/05/2010 - 13:53
Post your config....
And you said that you "added the same 10.10.10.10/24."
The original address in the config is 10.10.10.1 255.255.255.0. Is that a typo?
EH1165305 Wed, 05/05/2010 - 14:03
Sorry, yes a typo. I added the same (10.10.10.1/ 24)
Here comes the running-config:
yourname#sh run
Current configuration : 6480 bytes
! Last configuration change at 08:43:42 UTC Thu Apr 29 2010 by Router876W
version 15.0
hostname yourname
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa session-id common
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
        quit
dot11 syslog
dot11 ssid 876W
vlan 1
authentication open
wpa-psk ascii 0
ip source-route
   import all
   lease 0 2
ip cef
ip name-server 195.121.1.66
ip name-server 195.121.1.34
no ipv6 cef
bridge irb
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
pvc 8/48
no ip address
ssid 876W
mbssid
station-role root
no cdp enable
bridge-group 1
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface Dialer0
ip address 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username password 0
no cdp enable
interface BVI1
ip nat inside
ip http server
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
end
John Blakley Wed, 05/05/2010 - 14:07
Try putting:
bridge 1 route ip
Also, can you get an association with the AP and get an address? Can you ping the 10.10.10.1 address after you associate? And remove the "ip tcp adjust-mss 1452" from vlan 1.....
EH1165305 Wed, 05/05/2010 - 14:38
Thanks. Wireless is now working. I have a connection with internet on my connected Iphone.
Strange enough though now wired internet is not working anymore
On the connected console I can ping my DNS from within the console-connection. Also get a addressresolution for www.google.nl. I can ping my Iphone. I can not ping my ISP IP adress though!
On my wired laptop the internet browser does not find google or other addresses. In the dos prompt I can not ping to my own ISP address, no DNS.
What I did was as you suggested bridge 1 route ip and removed "ip tcp adjust-mss 1452" from vlan 1.
Some suggestions left... Would make me very happy
John Blakley Wed, 05/05/2010 - 14:41
Yep...try:
bridge 1 protocol ieee
See if that gets your wired side working, and you should be good....
John
EH1165305 Wed, 05/05/2010 - 14:53
Thanks for your very fast responding as I'm in the middle of the night and have to get up in a few hours. But this is important for me and I hope to solve it with your help.
Unfortunately nothing changed!
I can ping my Iphone yes. But still no internet from the wired connected laptop. I did not see a change after bridge 1 protocol ieee command....
John Blakley Wed, 05/05/2010 - 14:55
Hmmm.....are you getting an address on the wired side? Can you ping the router at 10.10.10.1?
Also, what port are you connected to? Are you connected to the switch on the router or another switch that's connected to the router? What port is that connected to on the router?
EH1165305 Wed, 05/05/2010 - 15:17
Sorry about taking so long. Have to plug and unplug on my two routers for connection to you.
I cannot ping out of the laptop to the router. Which I could before I got it wireless.
Tried F0 and after that also F4. Both don't give ping possible.
I have a switch, but for this "exercise" I made the connections directly to the router. The switch is not connected now. The IP address I gave the laptop is 10.10.10.4 and should be ok with DNS, gateway and mask set.
I don't know if it is of interest but I did a sh ip int brief and saw that the BVI1 is not up so I did a manual no shut.
This unfortunately did not solve the problem either and I hope I did not disturb your thinking about the solution.
Here is the output:
yourname#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
ATM0.1                     unassigned      YES unset  up                    up
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
BVI1                       10.10.10.1      YES manual up                    up
Dialer0                    213.xx.xx.xx   YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
Vlan1                      unassigned      YES manual up                    down
And my intervention to get the BVI1 up
yourname(config)#int BVI1
yourname(config-if)#no shut
yourname(config-if)#exit
yourname(config)#exit
See now that is was up but what is down is the BVI1. Don't know if this is important and how to solve....
John Blakley Thu, 05/06/2010 - 04:13
Sorry. I replied to you yesterday from my phone by replying to the email, but it didn't post apparently.
On the port that you're connected to in the router, change that port to a trunk port. I'm not sure if that will do anything, but that's the only difference between yours and my 871W that I have configured. So, if you're connected to FA0, try:
int fa0
switch mode trunk
Let me know if this did anything. Also, after you do that, if you haven't rebooted you may want to try that as well.
HTH,
John
EH1165305 Thu, 05/06/2010 - 08:53
Thanks John you did not give up. I went to bed and did not get any messages anymore. So I thought that was it. Problem cannot be solved. Maybe a hardware issue, although strange.
But... you made my day.
After I gave the swithport command, which I will try to undo also later on this day as I have no time at the moment, nothing changed.
Than I did the copy run start and rebootet.
And thanks God I'm online now with the 876W router wired to my laptop! And also my Iphone is still working wireless connected.
You cannot imagine how glad I am
Now I don't know what went wrong and if I should have rebooted earlier on the problem would be solved before the last issues, where you where stonnishing about not functioning after your great help. But anyhow it functions wireless and wired to at the moment.
Later on in the weekend I have some more time and will have a look if I can get my Cisco switch again inbetween as the rest of my computers now is ofline.
Again thank you very much for your great consistent and appreciated help. You earn a goldmedail!
Emil
Message was edited by: Emil Heilbron I did a no switch trunk and now the switch is inbetween again. Maybe I can ask you a last question as I detected that my other computers are not in the range of IP addresses. How can I make some more IP addresses connect to the router? Thanks
Correct Answer
John Blakley Thu, 05/06/2010 - 09:04
Thanks!
John
EH1165305 Thu, 05/06/2010 - 09:23
I rearanged the access-list 1. After your lessons I forgot everything
Thanks again.
Related Content
