1400 Series IOS Command
May 5th, 2010
Does anyone know what is the command I can use to show me the signal strength of the antennas during the installation process?
What I have been doing is to do a linktest and then show log to see what happenned.  I think there should be a better way that the screen will update with all the data when there is a change in signals strength.
Thank you.
dancampb Wed, 05/05/2010 - 07:55
If the bridges are associated then you can see the signal strength and SNR under "show dot11 assoc "
vcscadaboy Wed, 05/05/2010 - 08:00
What about before the bridges associated?  I'm trying to aim the antennas and if I can see whenever there is a signal strength that would be good.
Thank you
