Is CUCIMOC 7.1(4) compatible with CUCM 8.0(1)?
May 5th, 2010
Hi All,
anyone know if the CUCIMOC release 7.1(4) (the latest version available in the download area) is compatible with a cluster of CUCM 8.0(1)?
I'm not able to find a document in Cisco web site where is specifically written, the only info i've found are the CUCIMOC release notes that says compatible with:
7.1(3)10000-11 or later
7.1(2) or later
7.0(2a) SU1 or later
6.1(4) or later
6.1(3) or later, with Cisco Options Package (COP) file to create the  Client Services Framework device type
Should i suppose that "or later" means any minor o major release after the 7.1(3)10000-11? So even the release 8.0(1)?
Thx
Christian
htluo Wed, 05/05/2010 - 10:04
I couldn't find anything either.  But it should work.  Because the integration point between CUCIMOC and CUCM was CCMCIP and CTI.  Those interfaces didn't change on CUCM 8.0.
Michael
http://htluo.blogspot.com
Related Content
