IPM 4.2.0 "No data is available for the selected time period"
Answered Question
May 5th, 2010
I have 32 collectors on the same source device monitoring various distributions throughout our enterprise. I set these up approximately a week ago, and am unable to pull any information. They are no the default 60 minute cycle, utilizing UDP jitter. I ensure I select the proper graph settings to coincide with the collector. The statistics on the source switch (via CLI) seem fine...thoughts?
Correct Answer by Joe Clarke about 6 years 9 months ago
While the IP SLA commands exist on earlier code, the feature was not officially supported (i.e. fully committed and tested) before 12.2(40)SE.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 05/05/2010 - 22:17
Exactly what button did you click to get this error?  How did you define these collectors in IPM?  Are they Historical or Real-time?
Joe Clarke Thu, 05/06/2010 - 22:40
If you click the Monitor button instead, do you get any data in the resulting graphs?
readytolearncisco Sat, 05/08/2010 - 19:28
Joe, I added 31 additional collectors sourced from a different device. Following this configuration modification it seems that all of the collectors are functioning properly. Thoughts on this? Thanks.
Joe Clarke Sat, 05/08/2010 - 20:11
Perhaps there is a bug on the previous source device where the historical IP SLA data cannot be properly polled.  Without more details, I cannot say for certain.
readytolearncisco Sat, 05/08/2010 - 20:19
The original source is a couple of 3750-12s stacked, running c3750-ipbasek9-mz.122-25.SEE1.
readytolearncisco Sat, 05/08/2010 - 20:34
That would explain it :-) I know it actually runs RTR, not SLA, but figured since IPM configured it that it was supported.
Correct Answer
Joe Clarke Sun, 05/09/2010 - 14:25
readytolearncisco Sun, 05/09/2010 - 14:56
Thanks Joe. I think I'll simply remove the collectors from this source device. You're expertise, as always, is much apprecaited.
