Phone Loads
May 5th, 2010
I have got Cisco-520  with 16 user license and I  am going implement IP telephony in our environment for the first time.
I have few pre-implementation questions
1. I saw in the specification that this model supports all latest models of Cisco IP phones  and most of the settings are pre-configured to support for small businesses. So in this case When I connect an IP phone to the router's PoE port will the phone auto-register and get its firmware and the configuration?
or do I need to specify the phone loads for each model ?
2. In case If I need to load the firmware and settings manually in CME what steps I need to perform? will I be able to do it from CCA ?
also suggest me any other steps to connect my IP Phones and make them work with their internal extensions (I have already created internal dial peers )
bigdaddyajay Wed, 05/05/2010 - 12:44
1-The auto get their firmware once you plug them in.  They don't register automatically though, you need to do that through CCA.
2-You can do it from CCA.  When you upgrade the Software pack for the UC520, it has the phone loads on them
https://www.myciscocommunity.com/docs/DOC-10361
I think you just pick which ones you want to install
sunilgavaskar Thu, 05/06/2010 - 03:26
Thanks for the info. I have the Software pack version 8.0.0 installed on my UC-520.
I tried with Cisco IP communicator installed on my system. It auto registered and got an extension automatically.
if I update my software pack for UC-520 to later version will it erase my existing configuration?
I also wanted to know how to check the phone load files from the flash. there are many files on the flash I do not know which files are phone load files/
how can I know what files are associated with which phone load. is there any  site available so that I can check which file to load for specific phone model ?
Marcos Hernandez Thu, 05/06/2010 - 07:33
  • Blue, 1500 points or more
The upgrade should nto delete your existing config. For phone-load to phone association, you can inspect the "show running-config" and look for the "tftp-server" commands. They will indicate the mapping.
Marcos
sunilgavaskar Thu, 05/06/2010 - 07:44
I have checked the running-config. but I am unable to identify which loads file corresponds to which phone model.
these are few commands I found.
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:S00104000100.sbn
tftp-server flash:cmterm_7936.3-3-5-0.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sbn
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.bin
tftp-server flash:cmterm-7941-7961-sccp.7.0.3.tar
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
Marcos Hernandez Thu, 05/06/2010 - 07:49
After the upgrade and when you move to the new directory structure you will see the correct correspondence. Now, it seems that you are on an old version of the configuration. When was the last time you used CCA? You might need to start from a brand new config after all. We do not support upgrading from the very early releases.
Marcos
sunilgavaskar Thu, 05/06/2010 - 07:53
I have used CCA yesterday. what version upgrade would you suggest ?
Marcos Hernandez Thu, 05/06/2010 - 08:00
Use latest CCA 2.2.2 and latest Software pack 8.0.1
Marcos
sunilgavaskar Thu, 05/06/2010 - 08:07
Thanks for the suggestion Marcos. Currently I am using  CCA 2.2.2 and planning to upgrade to the pack 8.0.1
I still have some confusion on the follwoing
when I purchased this UC-520 box most of the configuration was there already like the dial-peers for analog extensions and the VOIP dial peers  for IP phone extensions which starts from 201 -218,  also translation rules were also pre configured.
after the upgrade do I need to perform all these configurations?  or as you said all the existing config will remain same ?
Marcos Hernandez Thu, 05/06/2010 - 14:30
I don't think that you will need to reconfigure. It might be a good idea to do a backup prior to the upgrade.
Marcos
sunilgavaskar Thu, 05/06/2010 - 15:25
Yes. I took the backup of current config. I will perform the upgrade  and  will update you the results.
Thanks for  your assistance.
