Unable to access 1811w router from the Internet
May 5th, 2010
I am having an unusual issue.  I think I set up the zone security correctly to permit any IP from the out-zone to connect to the router via SSH and HTTPS, but my connections from the out-zone just time out.  The relevant portions of the config is attached.  Please help, I have been banging my head on the wall regarding this for some time now.  Thanks.
Panos Kampanakis Wed, 05/05/2010 - 14:07
  • Cisco Employee,
Your out to self zone pair seems to be inspecting tcp ports 22 and 443, so it all looks fine!
I am not sure why it is failing.
Maybe no self signed cert on the router?
You can also enable "ip inspect log drop" and check the logs to see if ZBF is for some reason dropping your TCP conn attempts.
I hope it helps you move forward.
PK
kietung888 Wed, 05/05/2010 - 14:16
Thanks for looking at the config.  Did some more testing and even when I remove the interface from the zones and used the traditional acl based method of inspection, it still did not work.  I used the following:
ip inspect test01
inspect tcp
inspect udp
inspect icmp
ip access-list ext test02 permit tcp any any eq 22
ip access-list ext test02 permit tcp any any eq 443
int fa0
ip nat outside
ip access-group test02 in
ip inspect test01 out
int bvi1
ip nat inside
I even tried opening everything from out-zone to self and it didn't work as well.  Even tried upgrading the IOS to the 15 line.  I could SSH and SSL VPN to the router from inside so I do not think it is an issue with the certificate.
Pretty sure the problem is not with the circuit.  We upgraded to business class cable modem and even when I connected a laptop directly to the outside interface of the router, I was still not able to connect.  Has anyone seen this before?  Could it be defective hardware?
astripat Wed, 05/05/2010 - 14:15
If you want to manage the router using ssh/telnet/http, you need to define the traffic under out-to-self policy. Please make the following changes:
class-map type inspect match-any manage
match protocol tcp
policy-map type inspect ccp-permit
class type inspect manage
  inspect
no class type inspect sdm-cls-ccp-permit-3
no class type inspect SDM_VPN_PT
no class type inspect RemoteConnections
  inspect
  inspect
  inspect
If it still fails, enable "ip inspect log drop-pkt" and send me the logs so that we can see in which class the traffic gets dropped.
Ashu
kietung888 Wed, 05/05/2010 - 14:32
I think that is how I have it configured currently.  Here is an excerpt from my config:
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
  inspect
  inspect
  inspect
class class-default
  drop
class-map type inspect match-any RemoteConnections
match access-group 113
access-list 113 permit tcp any any eq 22
access-list 113 permit tcp any any eq 443
class-map type inspect match-all sdm-cls-ccp-permit-3
match class-map ICMPAllow
match access-group name AllowICMP
ip access-list extended AllowICMP
remark CCP_ACL Category=128
permit ip any any
class-map type inspect match-any ICMPAllow
match protocol icmp
class-map type inspect match-all SDM_VPN_PT
match access-group 103
access-list 103 permit ip host x.x.x.x any
I was unable to inspect a class map that matched a protocol to the self zone.  So I had to create an ACL to perform that function.  At one point, I changed access-list 113 to permit ip any any and it still did not work.  Ip inspect log drop-pkt is enabled, I will have to gather up the logs the next time I am there.
Any other thoughts?
Panos Kampanakis Thu, 05/06/2010 - 10:13
  • Cisco Employee,
You can try to capture packets to the router. If you can ping it and you see no SYN-ACK coming back probably the router is dropping traffic and it is  ZBF.
The "sh log | i FW" will show you what ZBF says for packets it sees and drops.
PK
Related Content
