ASA sending RST packet
Answered Question
May 5th, 2010
Don't if im being really dumb, but ive got an ASA setup as VPN concentrator. Which works fine, my issue is that the ASA is sending a RST/ACK packet back to a host when it's dropped by an ACL.
Has anyone come accross this ?
Correct Answer by astripat about 7 years 2 weeks ago
Hi Stephen
By default "service resetoutbound" is enabled for all interfaces on the firewall. This command is used to enable resets for denied TCP connections. You can disbale this by entering the following command in the config mode:
no service resetoutbound
More information can be found here:
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s1_72.html#wp1290652
Ashu
Overall Rating: 5 (1 ratings)
Federico Coto F... Wed, 05/05/2010 - 12:09
  • Green, 3000 points or more
Is the ASA doing TCP intercept for the inside hosts?
Federico.
Correct Answer
astripat Wed, 05/05/2010 - 12:46
Hi Stephen
Ashu
