Jaime Valencia Wed, 05/05/2010 - 12:38
  • Cisco Employee,
  • Hall of Fame,
    2011
No, 4.0(5) is the minimum.
Lindborg has already addressed this in the past:
https://supportforums.cisco.com/message/1208732#1208732
1. COBRAS will only export from Unity 4.0(5) and later - 4.0(4) will not allow exports (the DB functions COBRAS uses were not all in place until the 4.0(5) release).  You'll have to upgrade to 4.0(5) or later to use COBRAS.
COBRAS help also explains 4.0(5) is the minimum you need to use the tool
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
David Hailey Wed, 05/05/2010 - 18:50
  • Purple, 4500 points or more
Java is 100% accurate.  DB constructs in earlier versions of Unity do not support the functions that COBRAS is using to pull data - they simply aren't there.  Must be at 4.0(5) or higher.
Hailey
