WLAN Identifier
May 5th, 2010
I have this issue where i have two wism's with the same amount of WLAN's and the same names: 15 to be exact.  The problem i'm having is that the WLAN identifier is different between the two wism's even though there are the same amount and the same name WLAN's.  I'm not sure if this causing me to have problems when applying a template for WLAN override through WCS because sometimes the change does not take effect.  Is there anyway to change the WLAN identifier number?
