Configuration assistance on a new 4900m
Im having difficulties getting pass this vrf command on the 4900m using the management port. Just hoping for any guidance that can get this switch simply connected and used for a management IP.
Snippet of the config
ip vrf mgmtVrf
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1
ip vrf forwarding mgmtVrf
ip address 10.10.10.10 255.255.255.0
speed auto
duplex auto
What do I need to do to get a simple IP onto the FA port (assuming the FA port is the mgmt port) and to make it accessible from anywhere in our internal network.  I understand the ip configuration and gateway but I dont understand the vrf portion.  tyvm in advance
Jon Marshall Wed, 05/05/2010 - 16:22
[email protected]
speed auto
duplex auto
Eric
Try adding a default route for the vrf ie.
ip route vrf mgmgtVrf 0.0.0.0 0.0.0.0
Jon
Giuseppe Larosa Thu, 05/06/2010 - 06:48
Hello Eric,
you may need to add an rd under VRF configuration.
An rd has to be configured in order to start the VRF object.
ip vrf mgmtVrf
rd 100:100
Other users have reported problems in accessing TACACS+ AAA server without this parameter
This is a miss in documentation
Then, as Jon has suggested you need a default route in VRF to give reachability of other IP subnets
Edit:
to be noted this is thought for a form of logical out of band management
you can use an SVI in vlan X as your management address without dealing with VRFs
I've checked in some recent installed 4948-10GE and we used an SVI in global routing table instead of the management VRF.
Hope to help
Giuseppe
