OSPF Adjacency
May 5th, 2010
Hi serniors,
I have Lan/Wan setup in my office with Cisco routers & switches. OSPF is running on serial as well as multiaccess network. Yesterday I noticed that 2 routers changed adjacency from FULL/DROTHER to 2WAY/DROTHER. Network is running fine without any outage and impact. Later I noticed that a switch is installed on both of these routers interface that changed the adjacency but switch ports are up and running. My question is
  • why routers changed the OSPF adjacency ?
Thanks.
Tahir.
Reza Sharifi Wed, 05/05/2010 - 17:51
  • Cisco Designated VIP,
    2017 LAN
Hi Thair,
Did you add another router connecting to you current 2 routers using the same subnet.
This usually happens when you have 3 or more routers on the same subnet, one route is Designated Router (DR) and one Backup Designated Router (BDR). All other routers have a two-way adjacency established. This is normal behavior for OSPF.
http://www.ciscosystems.net.ph/en/US/tech/tk365/technologies_tech_note09186a0080094059.shtml#routers
Reza
tahir1234 Wed, 05/05/2010 - 18:28
hi
Nothing was added in that particular network. In that particular network there are 8 routers on the multiaccess network and definately on some segments there are DR and on the other therer are BDR. Routers have FULL/DR and FULL/BDR adjacency on other ports but on a certain port (as i told before) , the adjacency was FULL/DROTHER that changed to 2WAY/DROTHER. My concern is that "WHAT caused this change?" Moreover when i see the router logs , it displays that adjacency changed from full to 2way & when i run "show cdp neighbor" on both routers , neither is in the cdp neighbor list while they are connected. No one changed the priority on the routers as well.
Thanks.
