Dynamic Vlan Assignment--Any large scale alternatives to obsolete VMPS?
May 5th, 2010
I've had the pleasure, or displeasure for those who may, of working on a 600-700 devi
ce(7000-10000) user base network with Open vmpsd as the vlan assignment method. Granted it's been rendered obsolete, and no longer supported on newer devices, is there an alternative vlan assignment scheme flexible enough to work well with this size of a network, and with NAC deployment taking foot, work well with this technology?? What vlan assignment solutions would you recommend in a network with thousands of ports in need of effective vlan assignment, yet secure enough to pass US Gov Standards.
Ganesh Hariharan Wed, 05/05/2010 - 23:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
What i would suggest go with Dynamic VLAN Assignment with RADIUS Server,check out the below link for the same !!
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Giuseppe Larosa Thu, 05/06/2010 - 06:45
  • Hall of Fame,
    Founding Member
Hello Dim,
you may want to consider also 802.1X for vlan assignment if there are security requirements
Vlan can be assigned during 802.1X port authentication:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/dot1x.html#wp1240472
But I'm afraid it can be not compatible with Cisco NAC.
Hope to help
Giuseppe
