Technical documentation for Phone Proxy
May 5th, 2010
We've got a couple of phones connecting to CUCM via Phone Proxy and we're having an issue with accessing the CUCM directory service from the phones.  Can somebody point me to the documentation which details the requirements of setting up the directory service to work thru the ASA?
Overall Rating: 5 (1 ratings)
William Bell Wed, 05/05/2010 - 22:37
  • Purple, 4500 points or more
Here is a link to the config guide.
http://www.cisco.com/en/US/partner/docs/security/asa/asa82/configuration...
Based on my understanding, because the ASA requires that URLs leverage HTTPs you need to have a web proxy available to handle the URL requests for XML-based apps from the IP phone (e.g. EM, corporate directory, etc.).
You can configure this as follows:
phone-proxy asa_phone_proxy
proxy-server address 128.106.254.9 interface outside
This aspect of the configuration is documented in bug/defect id: CSCsx08256
Bug Details
Remote Phones can not use services without external proxy server
Symptom:
Phone registered to CUCM via internet using Phone Proxy can not use service key or corporate directory
Conditions:
Phone is registered to CUCM via internet using Phone proxy
Workaround:
Install external proxy server.
Configure Proxy Server address in ASA Phone Proxy
Please refer to ASA Phone Proxy Configuration guide for more detail
HTH.
Bill
Please remember to rate helpful posts.
