VPN concurrent connections on 2811 router and Web VPN
junshah22
I have Cisco 2811 router and configured soft vpn on it,, my company's vendors access our ERP system via Cisco VPN Client,
I want to know,
1, How many users can connect simultaneously, by default, what is the limit (10 users ? )
2, If the concurrent connections limit is 10 , how can I upgrade it upto 300
3, Can I use SSL Web VPN instead of using Cisco VPN Client on users,,
4, We installed our Software Exe on clients PCs, they use our software,
I am interested to use SSL Web VPN instead of Cisco VPN Client,
Please advise..
Junaid
Ganesh Hariharan
I want to know,
Please advise..
Junaid
Hi Junaid,
Check out the below link for cisco 2811 router for support for comcurrent vpn connections
http://ciscosystems.com/en/US/products/ps5881/index.html
Hope to Help !!
Ganesh.H
If helpful do rate the post
Dear Ganesh,
Support of up to 1500 VPN tunnels with the AIM-EPII-PLUS Module,
this module will be required for 1500 vpn tunnels,,  I want to know, by default how many vpn tunnels it supports without this module...
secondly I asked, Web VPN can be used as alternative of client vpn ,, ??
Junaid
Hi Junaid,
By default the Cisco 2811 supported 200 vpn connections with k9 bundle.
If you want to use morethan 200 connections then you need to insert aditional AIM module.
Please rate if this helped you...
Naidu.
