Enable password not working through local logging
May 6th, 2010
Here is problem with switch 6509, I am able to get logging through the ACS password. But when ACS is not in network i am able to get logging through local user name / password.
getting enable mode, when type the enable password switch is not taking and i am not able to get access.
Wt RO.......
spremkumar Thu, 05/06/2010 - 01:23
  • Red, 2250 points or more
Can you post the config related to AAA ?
regs
spremkumar Thu, 05/06/2010 - 01:37
hi
Do remove this file and attach the config file. check before attaching here.
regds
Ganesh Hariharan Thu, 05/06/2010 - 01:38
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Re: Enable password not working through local logging
Find the att. file for AAA.
It is not having the configuration of AAA,any how check out the below link for configuring the aaa on switches/routers
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080093c81.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan Thu, 05/06/2010 - 02:04
Hi All,
Sorry i attached wrong file.
Ple find the att. AAA config file.
What is the error message are you getting in ACS under failed attempts logs when you try to login in to  switch.
Ganesh.H
jyotiraj_Majumd... Thu, 05/06/2010 - 02:19
No not any error
Just not taking enable password. when i try 3 -4 times it will come out.
Regard..
Jyoti
Ganesh Hariharan Thu, 05/06/2010 - 02:34
No not any error
Regard..
Jyoti
Jyoti,
Are you sure you are not getting any failed attempt message in ACS  when ever you are going into enable password ,do one thing in ACS you have option under user setting --tacas+enable password --select here as Use CiscoSecure PAP password.
Hope to help !!
Ganesh.H
jyotiraj_Majumd... Thu, 05/06/2010 - 22:58
Hi Ganesh,
I am trying the local user name and password when acs is down.
Help...
Regards.
Ganesh Hariharan Thu, 05/06/2010 - 23:13
No not any error
Regard..
Jyoti
Hi Joyti,
Is local username database is created when your are trying and also can you post your config.
Just go thourgh this link also when acs goes down local database comes in picture
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080093c81.shtml#cfg_auth
Hope to Help !!
Ganesh.H
spremkumar Thu, 05/06/2010 - 02:09
hi
try this and revert.
no aaa authorization config-commands
no aaa authorization exec default group tacacs+ if-authenticated
no aaa accounting suppress null-username
no aaa accounting exec default start-stop group tacacs+
aaa authorization console
aaa authorization configuration default group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting commands 5 default start-stop group tacacs+
regds
Related Content
