Cisco ASA SSL VPN and ACS 5.1 change password
Answered Question
May 6th, 2010
Dear Sir,
     I'm tring to setup ASA to change local password on ACS 5.1. When user access with ssl vpn if password on ACS 5.1 expire. ASA will show dialog box or pop-up to change password. But It don't work. I'm tring to setup with password management feature on ASA . When I enable password management it don't work and can't to change password. Could you advise me about this problem?
Thank you
Aphichat
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Dear Sir,
Thank you
Aphichat
Hi Aphichat,
Check out the below link for password change promt via ACS in ASA:-
https://supportforums.cisco.com/docs/DOC-1328;jsessionid=A51E68318579261787BD60DDA0707819.node0
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Thu, 05/06/2010 - 02:56
Dear Sir,
Thank you
Aphichat
Hi Aphichat,
Hope to help !!
Ganesh.H
