configuration backup
Answered Question
May 6th, 2010
Hello there!
how are you doing today, guys? hope you are all fine.
I have some issue backing up my configuration, thought maybe you can help me here.see my problem below:
when I type "copy running-config tftp://x.x.x.x/hostname.txt" router require to repeate tftp-server address and destination file-name. how can I avoid it?
I mean I dont want enter or apply same things twice. Can I copy running-config to tftp only by one string - "copy running-config tftp://x.x.x.x/hostname.txt" ?
thank you for your time and attention!
Correct Answer by Ganesh Hariharan about 7 years 1 month ago
the thing is that i dont wanna be prompted like that. i just want to
copy run-config with one command. because I'm doing it with TCLscript
so I cant asnwer prompts this way.  Do I explore my self clear?
Configure file prompt quiet command in configuration mode of router/switch then try with copy command
Hope to Help !!
Ganesh.H
Correct Answer by stephenshaw about 7 years 1 month ago
this link appears to provide the information you are looking for. I haven't actually tried it and don't know which IOS versions support it but it's worth a look at:
http://blog.ioshints.info/2006/11/reduce-noise-generated-by-cisco-ios.html
Overall Rating: 5 (2 ratings)
Ganesh Hariharan Thu, 05/06/2010 - 02:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello there!
It's genrally a steps by cisco for taking backup in tftp,so better recommendation is to follow the below process for taking backup
CE_2#copy running-config tftp:
Address or name of remote host []? 64.104.207.171
Destination filename [ce_2-confg]? backup_cfg_for_my_router
1030 bytes copied in 2.489 secs (395 bytes/sec)
CE_2#
Hope to help !!
Ganesh.H
Remember to rate the helpful post
nafrasiyabov Thu, 05/06/2010 - 06:34
the thing is that i dont wanna be prompted like that. i just want to copy run-config with one command. because I'm doing it with TCLscript so I cant asnwer prompts this way.  Do I explore my self clear?
Correct Answer
Ganesh Hariharan Fri, 05/07/2010 - 04:15
Hope to Help !!
Ganesh.H
