Redundancy Edge Sw
May 6th, 2010
2960 needs reachability to backbone-sw when link between 2960 and 4509 is down
4509 is the server, All 2960 will be VTP client
On 4509
interface gi 0/1
switchport trunk encap dot1q
switchport mode trunk
interface gi 0/2
interface gi 0/3
On 2960 ( 1st floor )
interface gi 0/1
interface gi 0/2
On 2960 ( 2nd floor )
interface gi 0/1
interface gi 0/2
On 2960 ( 3rd floor )
interface gi 0/1
interface gi 0/2
Any additional configuration is needed to avoid loop if both connection port is up on 2960.
Mel
Jon Marshall Thu, 05/06/2010 - 03:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Melwin
No additional configuration needed as STP will automatically block one of the uplinks. I would recommend running RSTP rather than standard PVST+ as it is a lot quicker to failover and make sure the 4500 switch is STP root for all vlans.
Jon
melwin.uk Thu, 05/06/2010 - 04:39
Do I need additional configuration on 4509 for RSTP then mentioned.
Is any config needed on 2960 edge switches for RSTP
Switch(config)# spanning-tree mst configuration
Switch(config-mst)# instance 1 vlan 10-20
Switch(config-mst)# name region1
Switch(config-mst)# revision 1
Jon Marshall Thu, 05/06/2010 - 04:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
melwin.uk wrote:
Melwin
The above is config for MST not rapid-pvst+. See the attached docs for rapid-pvst+ config -
4500 -
4500 rstp
2960 -
2960 rstp
Jon
