UCCE Questions
May 6th, 2010
Team:
a) regarding ECC variables if the CTIOS does custom work on new ECC variables is there a way to look at the standard CVP ECC variables and ensure that they do not get corrupted? Is there any sql table  like TCD that will have the ECC data for each call?
b) Will the CTIOS log with some trace level or tool that dumps all the ECC for a call?
c) regarding RCD router error code could you point me to a 7.X troubleshooting document that lists them, what they mean and what to do
d) any useful SQL joins that will dump the RCD and corresponding TCD records for a call?
e) Regarding calls with same RCKday, RCK but unique sequence numbers is there a reference document explaining the characteristics of such calls?
Thank you.
david.macias Thu, 05/06/2010 - 06:04
  • Blue, 1500 points or more
     How do they get corrupted?  You can make them persistent and look at the TCV table.
     No, you can put your ECC variables in a PV and that will be in the CTIOS logs.
     Google is your friend.
     I've some a few posted on the forum.
     ICM database schema.
david
Edward Umansky Fri, 05/07/2010 - 08:51
  • Silver, 250 points or more
CTIOS should trace all call data along with the CallBegin event. I don't recall what trace level you need exactly for that.
