05-06-2010 08:14 AM - edited 03-15-2019 10:38 PM
Did you ever try to register this phones on CUCME 8.0?
I have CUCME 8.0 on the 2800 series router. I have successfully registered ip phone 7960 through SCCP and Linphone sip soft phone through voice register configuration mode. You can review the configuration below. I do not see this models at the list of supported models. http://cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet_c78-567246.html
Thanks for help
Sincerely yours
Sergey Bondarenko
voice register global
mode cme
source-address 10.62.60.217 port 5060
max-dn 144
max-pool 42
timezone 26
time-format 24
date-format D/M/Y
voice register dn 1
number 2006
name sip_8900
voice register dn 2
number 2007
name SB_laptop
voice register pool 1
id mac 9CAF.CAFF.9B1A
number 1 dn 1
codec g711ulaw
voice register pool 2
id mac 0021.7095.28DD
number 1 dn 2
codec g711ulaw
telephony-service
max-ephones 42
max-dn 144
ip source-address 10.62.60.217 port 2000
user-locale RU
network-locale RU
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 2005
ephone 1
device-security-mode none
mac-address 001B.D40B.C4DE
type 7960
button 1:1
Solved! Go to Solution.
05-06-2010 09:15 AM
Hi Sergey,
The 500 series IP Phones are only supported with the Small Business UC500 (520,540,560). They are not supported on CME.
This section below does not mention the 525G (As it is an older doc) but the restrictions do carry across to all 500 series models;
The Cisco Unified IP Phones 521G, 524G, 521SG, and 524SG address the communication needs of any Cisco Smart Business Communications System (SBCS) implementation. These phones are designed to work ***solely*** with the Cisco Unified Communications 500 Series for Small Business.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps9730/qanda_c67-466070.html
This is an excellent thread about the 9900 Series from the Cisco BU. It shows support for the 9900 series with CME later in 2010;
https://www.myciscocommunity.com/message/27875;jsessionid=2803C635EB8687EE4C7E09777FA4FD5B.node0
Hope this helps!
Rob
Please support CSC Helps Haiti
05-06-2010 02:15 PM
For the 9900 phone, you should have no major problem using another type for config purposes.
But, I have never tried myself.
05-06-2010 09:15 AM
Hi Sergey,
Hope this helps!
Rob
05-06-2010 02:15 PM
