WebVPN RDP Auto Signon with Radius
May 6th, 2010
We have an ASA5510 configured with SSL WebVPN.  We've also installed RDP plug-in and it it working fine with Radius.  Now, we would like to use auto-signon.  I've tried to configured it, however I haven't had much luck so far.
Has anyone configured auto-signon with RDP?  Does it work with Radius?
Thank you
jan.nielsen Thu, 05/06/2010 - 14:52
I seem to remember something with having to add a parameter to the rdp url where you tell i
t to use the logged in credentials to connect with on rdp. something like rdp://x
.x.x.x.x/username=CSCO_USER, but i am struggling to remember the specifics.
donglee36 Thu, 05/06/2010 - 19:41
Hi Jan,
Thanks for your reply.  It's actually " xxx.xxx.xxx.xxx/?username=username&password=password, but this is only for a single user.    Is there anyway I can pass the login credentials to radius server?  So, each user can login with his own credential.
Thanks again.
