Hello all
i have a question in regards to Agent-Based Routing. is there a way to get the status of the agent with something similar to a "get report statistic" before you send the call to that particular agent ?
if there isn't what happens if that agent is on not ready state, or if the agent is on a call ?
do you guys know a workaround
thank you
Cristobal
