Way in CAD to disable window with warnings, messages
May 6th, 2010
  • Silver, 250 points or more
Does anyone know if there is a way in agent desktop to disable the message window/dialog that pops up when they loose connection to server, or it reconnects?
Thanks, Erick
Aaron Harrison Thu, 05/06/2010 - 11:01
  • Community Spotlight Award,
    Member's Choice, May 2015
Not possible as far as I know - and you probably wouldn't want to, as the user needs to go 'ready' anyway - so if they didn't get the popup they probably wouldn't realize their state had changed.
Aaron
Please rate helpful posts...
