E1 line connection
Answered Question
May 6th, 2010
Currently I have a  VWIC2-1MFT-E1 and VWIC2-1MFT-G703 to install a voice link E1,  and a Cisco 3845 router equipped with PVDM2-32. The  only information I have is that the E1 will be channeled and unbalanced, so I would  like to know which of the two interfaces I use, what configuration and if I  also need something else.
Thank  you very much for the attention.
Correct Answer by paolo bevilacqua about 7 years 2 months ago
You can use either, and you need cab-e1-rj45PRI, or equivalent.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Fri, 05/07/2010 - 09:45
  • Hall of Fame,
    Founding Member
