how to recovery the username and password for cisco2951 router?
Answered Question
May 6th, 2010
Need help here,, forgot to remove the one time username and password , and now I can not log into the router anymore. I try to do the password recovery . But I failed , because I can not get ino the rommon mode.. ctrl + break, is not working.
I tried securtCRT and Putty, same ... someone can help me with it?
thanks a lot!
Correct Answer by Ganesh Hariharan about 6 years 8 months ago
thanks a lot!
Check out the below link for password recovery porcedure
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
Hope to Help !!
Ganesh.H
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Thu, 05/06/2010 - 22:41
thanks a lot!
Hope to Help !!
Ganesh.H
david_casey Sun, 05/09/2010 - 18:00
thanks a lot!
I've seen an issue like this with some types of USB-to-Serial adapters (specifically Belkin ones).  I chalked the problem up to a driver issue but was never able to resolve it.  In the end I simply bought a different brand of adapter and never had the problem again.
In short, if you're using a USB-to-Serial adapter, try using a different brand if one is available.
Dave
