Suspending Wireless Guests
May 6th, 2010
We have noticed that when we suspend a wireless client on our NAC Guest Server the user still remained authenticated.  Our setup is a WCS, 5 controllers with one dedicated as a guest controller and a NAC Guest Server.  If you suspend the user it does not disconnect them from the network it only prevents them from re-authenticating. In testing we were able to reboot a machine and stay authenticated.  If we manually disable the client from the WCS the user is dropped but can re-authenticate from a differant MAC address or a AP that is on a different controller as the manually disable client is on a per controller basis. Is there a way to better tie the NAC guest server into the WCS so when you suspend the account it does both tasks on all controllers? Seems you have to do both or there is a way for the client to get back on.
Jason
Lucien Avramov Thu, 05/06/2010 - 15:21
  • Red, 2250 points or more
This is a very good idea for an enhancement request.
Unfortunately no. the NGS does not communicate with WCS since WCS uses SNMP and thats how it configures the WLC.
As of today WLC + WCS is one solution for guest access and WLC + NGS another one.
It's either ones for now.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Related Content
Trending Topics - Security & Network
