DS3 with ethernet handoff
May 6th, 2010
I am getting a DS3 from XO communications with an ethernet handoff.  Do I need a special card to take the handoff?  (special being something other then the standard FA ports in a router).
Edison Ortiz Thu, 05/06/2010 - 13:50
  • Hall of Fame,
    Founding Member
Perhaps what they are referring to is a sub-rated LAN connection and the target speed will be similar to a DS3 (45Mbps).
You don't need any special module other than a LAN port for this hand-off. I suggest deploying QoS so you can shape the packets to a 45Mbps speed instead of the default interface speed which can be 100/1000
Edison
