Issues on NAC AD SSO
May 6th, 2010
During my Demo of the NAC solution I'm having a hard time with NAC's AD SSO. I have already added the AD on the server and the status is "STARTED" but when i logged on to the machine it doesn't perform SSO. I have checked that the CAS is not listening to PORT 8910 although I have allowed the required TCP and UDP ports. What could be the problem with this?
Vanessa Joy Zamora
Vanessa Joy Pascua Thu, 05/06/2010 - 20:51
Hi Guys,
In addition I'm using NAC 4.7.2 for the test machine I'm using Winows 7 OS.
Faisal Sehbai Tue, 05/11/2010 - 15:22
  • Gold, 750 points or more
Vanessa,
CAS should be listening on 8910. If it's not then somethings not right.
Please post your CAS logs here for review. Also what sort of AD are you authenticating against? (2k3/2k8/2k)?
Faisal
Faisal Sehbai Wed, 05/12/2010 - 19:07
Vanessa,
You didn't answer what your AD is. Also what version of CCA are you running? Windows 7 required 4.7.x of CCA.
HTH,
Faisal
Vanessa Joy Pascua Wed, 05/12/2010 - 19:27
Hi Faisal,
The AD that we are using is Windows Server 2003 and the NAC version is 4.7.2.
Vanessa
Faisal Sehbai Wed, 05/12/2010 - 20:05
Vanessa,
Okay. How did you run the ktpass command on your AD for the user that you're using for the CAS AD SSO setup?
Do you have the output saved from that ktpass run? Also can you verify what version of ktpass did you use?
Faisal
