Callmanager Express on 1861 with 3G-GSM module.
May 6th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Did anyone try Callmanager Express on an 1861 router with 3G-GSM module?
Setup is for 5 users in remote site.
Product
Description
C1861-4F-VSEC/K9
1861,8-user   CME,CUE,Ph Lic,4FXS,4FXO,8xPOE,HWIC slot,Adv IP
HWIC-3G-GSM
3GWWAN   HWIC-HSDPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz
Mudassir
paolo bevilacqua Mon, 05/10/2010 - 06:50
  • Hall of Fame,
    Founding Member
That should work no problems.
Note HWIC-3G-GSM is going EOS.
