Dot1x Issue on Cisco 2950 Switch
May 7th, 2010
I have a Cisco 2950 switch running with c2950-i6q4l2-mz.121-22.EA6.bin image.When i configure a Dot1x Port Control Auto on each interface the utilization on the Cisco 2950 goes high.The moment i remove Dot1x Port Control Auto command on every interface utilization comes to normal.
Please let me know if any idea on this why the switch is behavior like this....
Thanks & Regds,
Lalit
Kent Heide Fri, 05/07/2010 - 12:45
Most likely you are hitting a bug although I did not find anything in the bug toolkit that could resemblance this.
What process is stealing all your cpu? Please do a `show proc cpu` for me. I would start by grabbing the EA13 release and try the same with that to see if you experience the same issues.
